Home Built Tie Rod Question - JeepForum.com
post #1 of 20 Old 07-08-2013, 01:33 PM Thread Starter
taylor797
The passenger side tie rod end on my jeep is gone and I realize that the joint is part of the entire tie rod so I'd have to replace the entire tie rod. Advance sells the Moog tie rod for $160 but the left hand side threaded tie rod end is only $40. Is there any reason why I cannot cut off the old end and cut the threaded portion off a new driver side end and have it properly welded on? I have a cousin thats a certified welder. I notice they are welded from the factory. I'd still have the adjustment for the tie rod on the driver side threaded end.
Thank you!
taylor797 is offline
post #2 of 20 Old 07-08-2013, 01:42 PM
jbolty
jbolty's Avatar
If you are going to do that just make a new setup from dom tube. You can buy the threaded ends from ruffstuff and lots of other places.
jbolty is offline
post #3 of 20 Old 07-08-2013, 01:59 PM Thread Starter
taylor797
I was thinking of doing that, would it be worth it if I'm just going to use stock TREs? I don't feel like I need to upgrade to 1 tons
post #4 of 20 Old 07-08-2013, 07:24 PM Thread Starter
taylor797
Has anyone ever tried this?
post #5 of 20 Old 07-08-2013, 10:40 PM
timatoe
timatoe's Avatar
I did something somewhat similar with the draglink. I needed a longer draglink, I got one from a XJ which is quite a bit longer, cut it in half but welded it then sleeved it. For the tie rod, I simply got everything from Ruff Stuff and upgraded for well under $200.
timatoe is offline
post #6 of 20 Old 07-09-2013, 10:40 PM Thread Starter
taylor797
I ordered the full 7/8 heim steering kit from ruffstuff. Thanks guys!
post #7 of 20 Old 07-10-2013, 08:15 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I'm not sure if that's the same kit I got from them. I had to drill out the knuckle taper holes to straight 3/4". If you don't have a drill and bits that large, I bought a set from Harbor Freight that worked well, was an easy job.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #8 of 20 Old 07-10-2013, 08:20 AM Thread Starter
taylor797
Great to hear! I'll have to find a 3/4 bit but if I can't Harbor Freight sounds good
post #9 of 20 Old 07-10-2013, 08:21 AM
rambo3489
You will have to drill them out. You can buy a tapered insert but that to me is useless if your doing heim joints. Either way. Good call on the heim joints. Thats what I did. Its Heavy duty. Make sure you get safety washers. So you don't have a single shear situation.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #10 of 20 Old 07-10-2013, 08:23 AM
rambo3489
Use a vari bit (step bit) that goes to 3/4". Trust me here. It will mill the knuckle rather than **** it up because it twists and gouges the hole. Cast is soft
<a href="
THE YJ MY WAY</a>
post #11 of 20 Old 07-10-2013, 09:24 AM Thread Starter
taylor797
Thanks for the info on the step bit, I have a good one that should work perfect. I'll post pics of the steering when its on
post #12 of 20 Old 07-10-2013, 09:44 AM
TSEJEEPERS
Are you planning on keeping the tie rod and drag link tube?
If not are you planning on changing your steering to crossover steering?
Reason I ask is with the stock inverted y set up the drag link mounts to the tie rod.
With the stock rod it is a solid rod (at the passenger side) and even if you are able to weld a insert to the rod there will be no adjustment and not much thread contact.
If you go to tubing there will no be a place to mount your drag link unless you change it to cross over steering.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is online now
post #13 of 20 Old 07-10-2013, 03:04 PM Thread Starter
taylor797
I'll be mounting the drag link on top of the knuckle the same way I've seen them do on the other steering set ups such as this: http://www.jeepforum.com/forum/f12/7...ering-1321063/
Is this called crossover?
post #14 of 20 Old 07-10-2013, 03:24 PM
rambo3489
Yup. One type of it. The inverted Y is how it comes stock with the draglink attaching to the passenger side tie rod rend.
<a href="
THE YJ MY WAY</a>
post #15 of 20 Old 07-10-2013, 10:00 PM Thread Starter
taylor797
It's my DD and I've been reading good and bad reviews for road use. I already ordered so its too late but what do you guys think off the heim steering on road?
