-   -   Home Built Tie Rod Question (http://www.jeepforum.com/forum/f12/home-built-tie-rod-question-1546538/)
taylor797 07-08-2013 01:33 PM
The passenger side tie rod end on my jeep is gone and I realize that the joint is part of the entire tie rod so I'd have to replace the entire tie rod. Advance sells the Moog tie rod for $160 but the left hand side threaded tie rod end is only $40. Is there any reason why I cannot cut off the old end and cut the threaded portion off a new driver side end and have it properly welded on? I have a cousin thats a certified welder. I notice they are welded from the factory. I'd still have the adjustment for the tie rod on the driver side threaded end.
Thank you!
jbolty 07-08-2013 01:42 PM
If you are going to do that just make a new setup from dom tube. You can buy the threaded ends from ruffstuff and lots of other places.
taylor797 07-08-2013 01:59 PM
I was thinking of doing that, would it be worth it if I'm just going to use stock TREs? I don't feel like I need to upgrade to 1 tons
taylor797 07-08-2013 07:24 PM
Has anyone ever tried this?
timatoe 07-08-2013 10:40 PM
I did something somewhat similar with the draglink. I needed a longer draglink, I got one from a XJ which is quite a bit longer, cut it in half but welded it then sleeved it. For the tie rod, I simply got everything from Ruff Stuff and upgraded for well under $200.
taylor797 07-09-2013 10:40 PM
I ordered the full 7/8 heim steering kit from ruffstuff. Thanks guys!
JeeperDon 07-10-2013 08:15 AM
I'm not sure if that's the same kit I got from them. I had to drill out the knuckle taper holes to straight 3/4". If you don't have a drill and bits that large, I bought a set from Harbor Freight that worked well, was an easy job. :cheers2:
taylor797 07-10-2013 08:20 AM
Great to hear! I'll have to find a 3/4 bit but if I can't Harbor Freight sounds good
rambo3489 07-10-2013 08:21 AM
You will have to drill them out. You can buy a tapered insert but that to me is useless if your doing heim joints. Either way. Good call on the heim joints. Thats what I did. Its Heavy duty. Make sure you get safety washers. So you don't have a single shear situation.
rambo3489 07-10-2013 08:23 AM
Use a vari bit (step bit) that goes to 3/4". Trust me here. It will mill the knuckle rather than **** it up because it twists and gouges the hole. Cast is soft
taylor797 07-10-2013 09:24 AM
Thanks for the info on the step bit, I have a good one that should work perfect. I'll post pics of the steering when its on
TSEJEEPERS 07-10-2013 09:44 AM
Are you planning on keeping the tie rod and drag link tube?
If not are you planning on changing your steering to crossover steering?
Reason I ask is with the stock inverted y set up the drag link mounts to the tie rod.
With the stock rod it is a solid rod (at the passenger side) and even if you are able to weld a insert to the rod there will be no adjustment and not much thread contact.
If you go to tubing there will no be a place to mount your drag link unless you change it to cross over steering.
taylor797 07-10-2013 03:04 PM
I'll be mounting the drag link on top of the knuckle the same way I've seen them do on the other steering set ups such as this: http://www.jeepforum.com/forum/f12/7...ering-1321063/
Is this called crossover?
rambo3489 07-10-2013 03:24 PM
Yup. One type of it. The inverted Y is how it comes stock with the draglink attaching to the passenger side tie rod rend.
taylor797 07-10-2013 10:00 PM
It's my DD and I've been reading good and bad reviews for road use. I already ordered so its too late but what do you guys think off the heim steering on road?
The time now is 11:23 PM.
