home brew lift - JeepForum.com
post #1 of 10 Old 09-09-2013, 08:46 PM Thread Starter
longtravel1
1989 XJ Cherokee
home brew lift
Ive heard that the rear springs moved to the front will give some lift. Also XJ springs in the rear will give the YJ lift. Does anyone know if this is true? Or any ideas on getting 2-3 inches. Will a 1" body lift require extending anything? Gas filler, fan shroud, etc?
longtravel1 is offline
post #2 of 10 Old 09-09-2013, 09:06 PM
Norcal_chris
Norcal_chris's Avatar
The rewr springs have one more leaf in the springpack, so yes a small amount of lift.
Yes xj resr springs will give lift, but that requires gastank mods as well as relocating shackle mounts and lengething driveshaft as it moves the axle back 6inches
Usually a 1in body lift is no isse. You may have to trim a little fan shroud
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #3 of 10 Old 09-09-2013, 09:18 PM Thread Starter
longtravel1
1989 XJ Cherokee
Thanks Chris. Sounds like the Xj spring is not the way to go, What about shackle lift?
post #4 of 10 Old 09-09-2013, 09:20 PM
Michaelgoesrawr
1" body lift and 1" shackle lift. Don't go higher than those if avoidable. Steering changes with more shackle lift and more stress is put on the body mounts the higher you go.
Michaelgoesrawr is offline
post #5 of 10 Old 09-09-2013, 11:05 PM
YJ4LIFE
what size tires do you want to run? I had 31's with 1" BL and TJ flares for years.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #6 of 10 Old 09-09-2013, 11:11 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Don't forget the TJ flares^^
Luck Favours The Prepared
Anticanman is offline
post #7 of 10 Old 09-10-2013, 11:11 PM Thread Starter
longtravel1
1989 XJ Cherokee
I bought some 17" Rubicon wheels off a TJ and need clearance. Also what is the bolt pattern on a TJ? I think a 91 YJ is 5 on 4.5.
post #8 of 10 Old 09-10-2013, 11:16 PM
YJ4LIFE
Tj rubicons didn't have 17's they had 16's. If u got JK rims they're 5x5"
YJ4LIFE is offline
post #9 of 10 Old 09-10-2013, 11:16 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
TJ is the same as a Yj. Are you sure it is a TJ and not a jk?
post #10 of 10 Old 09-10-2013, 11:16 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Beat me by a second.
