| Rough Country TJ Belly Pan Skidplate Giveaway - NEW PRODUCT RELEASE |
| Best place to buy Rubicon Express! Don't Fear the Jeeper! | Insane Rough Country Deals Call for more Info!!! so insan | Barnes 4WD Universal 4 Link Kit |
| Jeep Registry | Register | Blogs | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
Toyta was wrong -
Holley Carb swap
Things are not what they used to be - Missing one inside of me Deathly lost, this can't be real - Cannot stand this hell I feel Emptiness is filing me - To the point of agony Growing darkness taking dawn - I was me, but now He's gone Holley Carb thread |
#2 |
sorry this is no help, but i bought my jeep with that exact carb. couldnt compare it to the stock carb, but compared to other cars with carbs, it seems to run much better. if my carb died though..id just go all out with fuel injection. but thats just me
#3 |
Toyta was wrong -
Thanks for the response.
I wish I had the money for the FI kit, but $2700 is hard to come by right now. Compared to the stock carb, it's a massive improvement. I swear I get better mileage now. I just had to have a custom adapter plate made to solve a vaccum leak and it helped but didn't solve the problem. Have you ever been into the carb? Do you know what size jets and power valve you have? How about injector nozzle size? I'm hoping it's just down to the right combo of the three to get rid of the stumble.
#4 |
Toyta was wrong -
TTT
Anyone else?
#5 |
Toyta was wrong -
Noone?
Surely there is someone in this fine country of ours that has doe this before that can give me some assistance. Any and all help/comments are appreicated/welcomed.
#6 | |
http://www.affordable-fuel-injection.com/amc-system.htm If my weber ever goes out that's what I'm shooting for.
PRCE7, 87 YJ stuff for sale: Posi-Lok 4X4 cable set-up, Warn differential guard, NP 231, YJ OEM drive shaft, Ford 9 inch rear-end, Dana 35, Front 1" extended bump stops, XJ Grille with both bezels, Dana 20, Torque Flight 727, here is the full detail: http://www.jeepforum.com/forum/showthread.php?t=479744 |
#7 |
Toyta was wrong -
Well, in case anyone ever wants to know, I did FINALLY get rid of my stumble. Ol Frankenstein is running like a champ, ever when cold.
- custom fab adaptor plate (no cheapo universal) - size 58 jets - 10.5" power valve (22" vaccum at idle) - 25cc accelerator pump (with taught adjustment screw) - and I believe a #42 injector nozzle but I may try and size it down and see how it runs. Yes, this is on a stock 4.2l rebuild. Runs like a small V8 in the warm months
#8 | |
Eat, Sleep, Jeep
So what actually solved the stumble? The adapter plate curing the vac leak? |
#9 | |
Toyta was wrong -
I talked to Holley tech support after making many adjustments that never really did anything. Came to the conclusion that it was indeed a lean stumble. The engine would run out of gas at a certain point in pedal travel (butterfly poistion vs engine vaccum). Adjusted the powervalve to my vaccum reading and corrected the accelerator pump & linkage (big help here!). The jet size came along in the middle of all this by looking at spark plugs and discussing it with another board member. The adaptor plate issue was always a concen to me so I just decided to spend the money to eliminate any possibility of a problem. I changed it straight out without any other adjustments and could tell a difference in operation. It was a wonderful addition as the shop that cut it for me beveled the throats from the Holley to the fcty manifold...made it out of 5/8 thk plate. BUT it wasn't until after I changed the plate that I could figure out the other adjustments. So yes, the plate put me on the path to success. Strange that I could never find the leak....
#10 |
I have had problems with my holley carb since I put it in, I think mine is a 250, but do not remember. Mabye I'll try a new adapter plate, and see where I go from there.
Mike
89 YJ Islander, White with blue pearl custom paint, 4.2 Nuttered, Holley carb, Light bar W/4 Kc daylighters, 32x11.50r15, Unknown lift, kenwood sound, Rockford fosgate Amp x2, Kicker Amp(1) A work in progress... 2006 Ram 1500 TRX4 5.7 HEMI All stock |
#11 | |
Toyta was wrong -
If you have the adaptor plate that has slots in the bolt pattern, it's leaking. That is what I replaced. I have a new digital camera on order, should be in tomorrow. I'll post pics of it. You guys have to see this plate they made for me. It's fabulous. Even the guys at Salvage Jeep thought it was great.
#12 | ||
#13 | |
Mike
#14 |
Toyta was wrong -
Ok, I know this has been a long time in coming but I finally got some pics of this custom fabricated plate. This is actually the second one, the first is on my motor. Wizard has been waiting on this one!
I have also added a fuel pressure regulator. More explanation on this later. It is definitely an added bonus.
Things are not what they used to be - Missing one inside of me Deathly lost, this can't be real - Cannot stand this hell I feel Emptiness is filing me - To the point of agony Growing darkness taking dawn - I was me, but now He's gone Holley Carb thread Last edited by zeus87gn; 03-15-2008 at 07:59 AM.. |
#15 |
Toyta was wrong -
FPR pics
Finally, a moment to breathe...
This has been quite the nice addition to my setup. Stinky exhaust virtually eliminated. No more black spots on startup (spitting from the tailpipe). Smoother operation. Better tuning response when adjusting the mixture. Just all around one d@mn good thing to have done. I highly recommend this to anyone running this carb. I presently have it set on 3-1/2. 4 was starting to get rich again, 3 made it lack some power. I'm still experimenting with it. I contacted Holley about this and they agreed it may be a good thing as the Holley is only made to run on 6-1/2 psi. I have read the stock FP on the old 4.2's puts out about 7 to 8 psi.
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Holley carb | KON | YJ Technical Forum | 5 | 02-01-2010 01:54 PM |
| Just Got A Holley Avenger Carb And... | saharajeepman | YJ Technical Forum | 8 | 01-11-2007 08:18 PM |
| Holley Carb on a 258 | jayr00 | YJ Technical Forum | 5 | 04-06-2006 11:13 AM |
| holley 2300 carb | ry1304 | YJ Technical Forum | 0 | 12-08-2004 08:05 PM |
| Holley 2 barrel carb | 90jeepman | YJ Technical Forum | 1 | 12-30-2002 04:09 PM |
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
