#1 | |
Holley carb
Anyone know or have of any holley carb conversions for the 88 258 6 ?????
#2 |
American to the Bone
You can go with the Holly 390 but you will need the offenhauser intake for the 4.2 from JC Whitney. The intake is about $240. I am not aware of any adapter for the stock manifold to a Holly and even if there was. I would be very leary. Hope this helps..Scot
At least two-thirds of our miseries spring from human stupidity, human malice and those great motivators and justifiers of malice and stupidity: idealism, dogmatism and proselytizing zeal on behalf of religous or political ideas. - Aldous Huxley |
#3 |
Eat, Sleep, Jeep
I have a 500 CFM Holley 360 on my 88 4.2, original manifold.
Obviously had to Nutter, and I used a 12 dollar carb adapter from Autozone. Had to fab up linkage peices and bracket mounts. Initially I liked it a lot. More power doesn't stall. No more carter hassles. But if I had to do it again, I'd say spend the extra 60 bucks and buy a webber. Much less hassle and a better carb. The minor vac leaks in the 4.2 are not to noticable on the webber, but on the holley they keep your idle up around 1400 and are a real nightmare to root out and solve. Good luck. |
#4 |
I have a holley 2300 on my 88 yj with an auto zone adapter that I had to drill the bolt holes out to fit. runs great. I had a webber 38/38 and it sucked. could never get it running rite.
#5 |
I have the Webber 34 DGEC. I haven't been able to get it to run right. At first I thought it was just an old worn out engine. I replaced the engine with a rebuilt one, but I could never get the Webber to run right on it either. It guess it wasn't the engine!?! Now I'm looking at an adapter plate and an old Ford 2bl carb.
#6 |
I was also running the Weber 34, what a pile of junk. I went with a Holley 350cfm 2 barrel I picked on Ebay for $30. I used a Mr.Gasket adapter plate, had to silicone to stop the vacuum leaks. I also had to custom fab the linkage using a bellcrank. I have an auto and cruise control so I had to retain the factory linkage.
1999 XJ 2 door, 4.0 HO, Auto trans, Rough Country 4.5" lift, Ion wheels, 33/12.50/15 BFGtires, Getting it ready for paint. 1987 Wrangler, 4.2L, Holley 350cfm carb, TF999 Auto trans, NP207 transfer case, Rough Country 4" lift, Mickey Thompson limited edition wheels, BFG 33/12.50/15 tires. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
