Holes in tub floor (not drain holes) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Holes in tub floor (not drain holes)
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!
Unread 03-24-2004, 10:25 PM   #1
soccergk2003
I have a couple of holes in my floor where the drivers side seat is mounted, the back left mount broke through the floor.
I'm gonna ask around for someone that can weld it up. Now here is the question, should I just bend the metal back up and weld it, or should I get a sheet of steel welded over the hole?
soccergk2003 is offline   Reply With Quote
Unread 03-25-2004, 06:58 PM   #2
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Without seeing pictures of the vehicle and the holes described it would be hard to give you advice.
The welder that you hire to do the welding might have a good idea on what to do to fix the problems with your Jeep.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
  • From street to trail, '88 YJ on 38" tires does it all well
  • Silver 2006 TJ Unlimited, zombie ready as the daily-driver
  • a Kawasaki KLR650 DualSport bike
NaeKid is offline   Reply With Quote
