Hole in the chassis? - JeepForum.com
post #1 of 5 Old 09-29-2011, 05:20 PM Thread Starter
Anghil
I've had my jeep for over a year now and I've had this problem for just as long. Every time it rains water leaks in and a puddle builds at the drivers feet. I suspect this is what caused the installed radio to short. I finally got a new radio and want to install it. But before I do I want to make sure to fix the leak issue. I've looked around the inside and out and can't seem to see where the problem is. I've even sat in the jeep as it's raining to determine the location of the problem. Is this common for a YJ or do I just need to keep looking?
Anghil is offline
post #2 of 5 Old 09-29-2011, 05:27 PM
SpikesHD
1987 YJ Wrangler
Lean on the drivers side of the hood and look at the bottom of the windshield frame.
See the foam gasket sticking out right there? Poke it with your finger and see how water could get in if it ran down the windshield and through a crack in that gasket.
The gaskets aren't that expensive and maybe an hour to replace.
Si vis pacem, para bellum.
SpikesHD is offline
post #3 of 5 Old 09-29-2011, 05:42 PM Thread Starter
Anghil
Well, I may be in luck. I just had my windshield replaced along with the gasket. Time to make some rain to test it. Thanks!
Anghil is offline
post #4 of 5 Old 09-29-2011, 09:42 PM
timatoe
timatoe's Avatar
Have you looked at the YJ FAQ's?
timatoe is offline
post #5 of 5 Old 10-02-2011, 07:40 PM
d-dub
Did you check the drain tube (1 1/2 diameter) in the engine compartment-fire wall, with a "duck bill" closure at the bottom of it? This was plugged and caused water to leak onto my feet every time it rained. This is the drain for the fresh air intake between your hood and windshield.
d-dub is offline
amc 360 in tj chassis? Sedorbrian TJ Wrangler Technical Forum 1 11-24-2010 08:42 PM
Chassis paint??? TexasPigHunter YJ Wrangler Technical Forum 2 05-29-2010 04:03 PM
TJ Tub on YJ Chassis MattBMiller YJ Wrangler Technical Forum 6 10-19-2009 05:00 PM
Chassis Mounting Hole Wallowed Out? Tommy R TJ Wrangler Technical Forum 9 05-01-2007 10:48 AM
Hole and Thread size of D44 Axle Vent hole JeepRocks86 TJ Wrangler Technical Forum 1 12-31-2006 04:07 PM
