Hoe do you get the stock steering wheel off? - JeepForum.com
post #1 of 6 Old 09-30-2009, 09:40 AM Thread Starter
Sidewinder
I'm installing a grant steering wheel today and I looked and don't know how to get the stock one off. Anybody know?
ASK ME ABOUT
Sidewinder is offline
post #2 of 6 Old 09-30-2009, 10:20 AM
muddy93
1987 FSJ Wagoneer
you can try just pulling on it(once the nut is removed). some people have had luck with hitting the nut whit a hammer(loosen it, but leave it on the shaft so you don't damage the threads), wile applying upward preasure to the wheel with your legs.
you can also rent a steering wheel puller from most parts stores.
when I swapped my wheel, neither of the first tow methods worked, and I didn't want to make the 30 mile drive to the parts store, so I just made a crude puller from some scrap I had lieing around. basically it was a piece of flat stock with 3 holes drilled in it. two smaller holes that match up with the smaller hoels that are on either side of the wheel, and one that lines up with the center of the colom. I threaded the center hole for a larger bolt, and ground down the end of the bolt so that it would sit in the little indention in the end of the colom. then I dound two smaller bolts that threaded into the wheel. once the flat stock was bolted to the wheel with the smaller bolts, I just turned the larger center bolt with a wrench, and it pulled the wheel right off.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 6 Old 09-30-2009, 10:24 AM
KMA Krawler
First you will need to disconnect the battery, then pull the horn cover off, take a phillips screwdriver and take off the three screws(oh yeah...remember how it goes back together) then you will need a wheel puller to take I believe a 19mm nut off. Then you will be ready to put your new one on.
Co-Founder/ Administrator
KMA Off-Road Jeep Club
KMA Krawler is offline
post #4 of 6 Old 09-30-2009, 10:28 AM
Camilo98
Search for how to remove the Ignition switch and there will be write ups on as you have to remove the steering wheel to access the switch. But here is a quick list.
If changing the Ignition switch as well if not ignore this tools list.
Its simple but you will need to go to Napa or an auto parts store and get a GM style lock plate compresser like this but cheaper (| Tool Professional). You might be able to rent one out from a auto parts too. The other thing to get or borrow is a nap ring pliers possible with interchangable tips ( they are inexpensive at some parts store). You can probably do it with out the pliers but just makes it easier.
1) pull horn button ( this comes off with your fingers)
2)remove steering wheel nut (might have to remove the 3 screws for the horn assembly, I'm sure I did but I cant remeber if you need to. Once you are in there you can figure out what is needed)
3) use steering wheel puller to remove wheel ( or just wiggle it around with your hands really well, use just a little penetrating oil if you want. It can be a pain if you dont have a puller with you!)
If you are changing your Ign switch as well...
4) use a lock plate compresser to release the snap ring on the lock plate. (snap right is on the shaft at the bottom and can sometimes be a pain to get off w/out the right snap ring removal pliers,
Camilo98 is offline
post #5 of 6 Old 09-30-2009, 12:36 PM Thread Starter
Sidewinder
Thanks guys. How do you get the horn cover out?
ASK ME ABOUT
post #6 of 6 Old 09-30-2009, 12:50 PM
RebuildRookie
just pull on it. there are 3 or or maybe 4 retaining tabs that keeps it snapped in.
you will probably have to give it a good tug, just dont jerk on it or you might break a tab or 2. ask me how I know.
Mine still attaches with one of the tabs broken off.
I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.
RebuildRookie is offline
Do wheel spacers make your steering wheel wobble at high speeds? bgndobe TJ Wrangler Technical Forum 22 07-20-2009 09:27 AM
PROBLEM: Vehicle/steering wheel/back right wheel shake badly. Black99ac TJ Wrangler Technical Forum 5 10-11-2007 01:41 PM
Stock steering wheel diameter???? newbomb YJ Wrangler Technical Forum 8 07-17-2007 05:26 PM
Stock steering wheel size? EJames1226 YJ Wrangler Technical Forum 6 07-27-2006 08:16 PM
Stock steering wheel install bryris YJ Wrangler Technical Forum 26 03-18-2006 07:55 AM
