Ho do you take off/put on a new belt on my YJ - JeepForum.com
post #1 of 9 Old 10-25-2001, 07:25 AM Thread Starter
AustinGT
The other day my belt started chirping so I went to autozone and bought a belt there. I went to replace it and could not find a way how. I am used to a tentioner pulley that you pull on to allow the belt to be taken off and put on. Can anyone tell me how or direct me to a website that would help. Thanks
AustinGT is offline
post #2 of 9 Old 10-25-2001, 01:12 PM
glm 87 wrangler
Not sure what model you have but on the 258
6cyl it is done by loosen the alternator bracket it also has a 3/8 ratchet hole to get leverage to help tighten or you can use a prybar.but if you have a 2.5 or 4.0 it may differ.But all in all check your alternator
to see if there is a slide bolt type.If is there you go...Hope this helps..
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 9 Old 10-25-2001, 03:08 PM
bonehead99
bonehead99's Avatar
if you have power steering you can also loosen it to slip the belt on.
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #4 of 9 Old 10-25-2001, 03:50 PM
Big92Jeep
Would help if I knew the year, but the power steering pump is probably your tension point.
-Remove Air cleaner assembly completely
-Right above the power steering pump fill cap there is a bolt at the top of the bracket loosen it, but don't remove.
-There are 2 bolts on the back of the power steering pump that are in slip channels. Again, loosen but don't remove.
- Then down in under the bottom of the power steering pump there are 2 bolts one is a locking bolt with the head point towards the radiator. Loosen it but don't remove it. Then there is a tension bolt where the head is pointing towards the fender well. Loosen it and your belt will gain/loose tension so it can be removed.
-Then reverse to tighten everything up
* I hate the design. It's to much work to replace the belt in my opinion. I have done it a few times. I belive the size is 13mm or close to it.
~Rick
2008 Unlimited Rubicon
"The weather is here, I wish you were beautiful"
Big92Jeep is offline
post #5 of 9 Old 10-25-2001, 05:00 PM
glm 87 wrangler
Man mine way differs from yalls sound like work!!
post #6 of 9 Old 10-26-2001, 07:59 AM Thread Starter
AustinGT
Sorry, I forgot to put the year...it is a '95. Thanks for the input, I am going to try this tonight.
AustinGT is offline
post #7 of 9 Old 10-26-2001, 06:05 PM
jpwranglr9
i changed a belt the alternater way it its tough. reaching the bolt and removing was easy, but getting it back was hard. then i had to loosen the power searing pump to tighten the belt anyways. so the next time i did it i just went the power searing rought and tightened it all up there and left the alternater alone.
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
post #8 of 9 Old 10-26-2001, 06:18 PM
I-4
I-4's Avatar
there is a idler pulley just below the power steering pump (on 4 bangers)loosen the pulley,then take and turn the bolt at the top of the idler pulley bracket.that is how you tension the belt properly.believe there is a similar set up on the 6 cylinder jeeps as well.you don't even have to fart w/ the alternator or power steering pump!
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
post #9 of 9 Old 10-26-2001, 10:44 PM
jeffy
jeffy's Avatar
I found it a PITA to get to the tension bolt under the PS pump. Instead of going that way, I just loosened the Alternator. Then used a prybar to re-apply tension to the belt and get the Alternator back in.
*** www.4BangerJP.com ***
jeffy is offline
Help 87 YJ belt? HARLEYX2 YJ Wrangler Technical Forum 9 06-26-2009 05:55 PM
My seat belt buzzer goes off when belt is in wildbadbill YJ Wrangler Technical Forum 7 04-15-2009 05:48 PM
New belt tensioner but my belt is still loose 02tjsport TJ Wrangler Technical Forum 4 02-26-2009 11:33 AM
how do I get the belt off/on rustyoke YJ Wrangler Technical Forum 10 05-29-2006 07:25 PM
4.2 v-belt to serpentine belt irocnrl89 YJ Wrangler Technical Forum 3 12-02-2005 11:26 AM
