Hit Bumps, VIOLENT SHAKING, death wobble? - JeepForum.com
post #1 of 25 Old 04-21-2010, 07:53 AM Thread Starter
RebuildRookie
Driving down the road hit a few bumps, the front end shakes violently. I have to slow down to about 40 then it goes away. I can stick my head out of the drivers side and see the front wheels bouncing. It mainly happens when I hit a bump on the PASSENGER side.
The whole front end and rear end is stock/original (shocks, springs, axle u joints, etc...). I know alot needs to be replaced, but any other ideas, to rule out anything else would be great.
I have visually checked and have found no broken or cracked parts.
I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.
RebuildRookie is offline
post #2 of 25 Old 04-21-2010, 07:57 AM
SloppyJoseph
New steering stabilizer? That might just cover up the problem but it could work. Maybe new tie rod ends, drag link, etc.
SloppyJoseph is offline
post #3 of 25 Old 04-21-2010, 08:24 AM
TheRealOldjeep
Have someone turn the steering wheel back and forth while you watch each tie rod end and ball joint. You should be able to tell which one is messed up.
Chuck P
94 YJ 2.5L/AW4 (Gone)
98 ZJ Limited 5.2 - sons car
97 TJ 2.5L/30RH - daughters car
My site
TheRealOldjeep is offline
post #4 of 25 Old 04-21-2010, 09:43 AM Thread Starter
RebuildRookie
I know the tie rod bushings need to be changed, cause the ones in it are the original. I will get to working on it this evening. Start there and see where it takes me.
Thanks
post #5 of 25 Old 04-22-2010, 07:08 AM Thread Starter
RebuildRookie
Alright, I jacked the front end up and had someone turn the steering wheel. I could not see anything that would be out of the ordinary with the tie rod ends. WHAT EXCATLY AM I LOOKING FOR?
I tried rocking the wheels top to bottom to see if something in the hubs were loose and they were solid, no movement.
Tie rod, drag link, sway bar, trac bar, all are in good shape and not bent.
Could it be something just as simple as bad shocks?
post #6 of 25 Old 04-22-2010, 07:19 AM
TheRealOldjeep
Don't jack the front end up, leave it sitting on the ground so that there is a load on the parts. What you are looking for is "slop" in the tierod ends - the socket starts moving before the pin.
Chuck P
My site
post #7 of 25 Old 04-22-2010, 07:21 AM Thread Starter
RebuildRookie
O.K., I feel like a tard now. That makes alot of sense.
post #8 of 25 Old 04-22-2010, 07:21 AM
kingcn
I just solved a front end shaking violently problem. Turns out my shackles were not torqued properly allowing them to move side to side.
_____________________________________________
Front: Dana 30 4.10: Yukon Chrome-molly axles / Super Joints & Lock-Rite locker
Rear: Dana 35 4.10: Yukon Chrome-molly axles & Lock-Rite locker
C & C Fab Tube Fenders (giving these guys a plug because they treated me so well)
Home brew oil-pan/bell housing skid plate and gas tank skid plate.
kingcn is offline
post #9 of 25 Old 04-22-2010, 07:22 AM Thread Starter
RebuildRookie
I am assuming the socket is on the top and the pin is the bottom piece?
post #10 of 25 Old 04-22-2010, 07:23 AM Thread Starter
RebuildRookie
checked that, they are torqued correctly.
post #11 of 25 Old 04-22-2010, 08:10 AM
jsahara24
what condition are your tires in?? I had a similar problem years back and when I got new tires it went away.
99' Jeep Cherokee Sport
07' Toyota Matrix
jsahara24 is offline
post #12 of 25 Old 04-22-2010, 08:17 AM
SloppyJoseph
Get a big *** pair of pliers. Put them on your tie rod ends. If you can sqeeze them and they move up and down, then you need new ones.
I'd assume you need new ones since you said it was all stock. I just ordered the Rugged Ridge HD Steering kit and a skyjacker stabilizer and it got here yesterday. I had my girlfriends birthday party last night and didn't get to put it on, but the parts look pretty stout. I ordered it from Autoanything.com for 202 shipped.
post #13 of 25 Old 04-22-2010, 08:51 AM Thread Starter
RebuildRookie
There in good shape, about 80-85% tread left and no bad marking on them. All the weights from balancing them are on them to.
I will try that when I get home this afternoon. I just went out to the parking lot with a co-worker and had them turn the wheel while I looked. Everything seemed to turn at the same time. But I did notice that there seems to be some spacing, so I think the big *** plier thing would help me out with seeing if that could be a problem.
post #14 of 25 Old 04-23-2010, 09:51 AM
jbeebe
after you check your tr ends, check your ball joints. from the side of the wheel push the top and bottom in and out to see if it can move a little like that. try to lift the wheel while someone looks at the ball joint to see if there is play. i just solved my severe death wobble by changing all 4 ball joints, it was hard to tell with the wheels on, but once i pressed them out, my old ones were absolutely toast.
jbeebe is offline
post #15 of 25 Old 04-23-2010, 09:31 PM
Missouribound
Start with the steering stabilizer....My Yj would wobble after going over railroad tracks so severely I would have to pull off the road and slow to a stop. A heavy duty stabilizer solved the problem.
Missouribound is offline
Death wobble when hitting bumps FritzTJ TJ Wrangler Technical Forum 7 02-11-2014 01:37 PM
Death Wobble cured, but wheel still shaking pretty bad dyenom TJ Wrangler Technical Forum 1 07-13-2009 07:15 AM
death wobble when i hit bumps t-bird TJ Wrangler Technical Forum 12 05-18-2009 06:55 PM
03 Rubicon Death Wobble (shaking) Dbower TJ Wrangler Technical Forum 15 06-18-2008 11:08 PM
Violent shaking- pretty sure its not death wobble geoff11 TJ Wrangler Technical Forum 2 09-16-2006 10:40 AM
