Jeep Enthusiast Forums banner
hit a bump..now my front left wheel area has a squeaking coming from it
2K views 6 replies 6 participants last post by  sk80soarus
#1 ·
basically the thread title explains it all...
doesnt seem to be any alignment problems or anything...and the rock wasnt that big...
so i dont think i bent anything.
what the heck could be wrong.
the squeakign happens more when i turn left...and sounds like it happens rotationally..(the faster the wheels spin..the faster it squeaks
#2 ·
hmm i have no clue but did u grease up all ur ball joints and everything
#3 ·
I'd be inclined to check your brakes. Could be your brake pad wear indicator (if your brake pads are worn down), and/or the bump jarred your brake hardware loose, causing the squeal.
#6 ·
This may sound very elementary, but if you haven't already, I'd check for loose lugnuts. The wheel will squeak as you described if your lugnuts are loose.
#7 ·
i think i know what it is...i was driving through some water and my brakes probably got a smigen of rust on them overnight bc the squeaking went away...everything is smooth...checked the bolts..eveyrthing looks fine...
i hit the brakes to clean them off and now the squeak is gone...
sound like that could be it?
Top
