Hit a bump and the Jeep goes sideways - JeepForum.com
post #1 of 8 Old 05-16-2010, 11:14 AM Thread Starter
cvorden
1987 YJ Wrangler
Ok first weekend I have been able to drive my YJ on the road. I was going down a back road (paved) and hit a bump about 30mph and the back end felt like it was coming around. I am planning on driving it down to the beach next month and I'm afraid if I hit a bump in the road when I am going 60 its going to get sideways and roll. Its an 87 with stock suspension. Any ideas? Thanks
cvorden is offline
post #2 of 8 Old 05-16-2010, 11:27 AM
dadstoys2
1987 YJ Wrangler
Well chances are that you have some suspension issues but with out seeing it or driving it I am not sure what way to point you. Can be partly from bad shocks to bad bushings front and rear.
~Rich
87 Wrangler Ford 302
2"bodylift 5"suspension 35" bfg A/Ts
Np435 trans w/ np205
dadstoys2 is offline
post #3 of 8 Old 05-16-2010, 11:27 AM
Sleuthhound
Has the rear track bar been removed, and the front one left in? I could be mistaken, but I believe if one is taken out and not the other, it can cause something similar to that to happen. Probably wrong though, so hopefully someone else will chime in.
Sleuthhound is offline
post #4 of 8 Old 05-16-2010, 11:28 AM
RockWoRM
RockWoRM's Avatar
stiff springs, stiff shocks, over inflated tires, loose shackles, loose u-bolts, turdy 5 getting ready to explode. Start with those.
WRM
j/k on the last one.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #5 of 8 Old 05-16-2010, 11:58 AM Thread Starter
cvorden
1987 YJ Wrangler
You guys are freaking genius!!! The back track bar is missing and the front is still on. Sorry for being such a noob when it comes to this stuff. Should I just buy a rear or take off the front?
cvorden is offline
post #6 of 8 Old 05-16-2010, 01:54 PM
postaldave
take the front off. period.
you do not need trac bars.
but that doesn't mean that was your problem
it still sounds like a something is binding in the rear.
if you stand on the rear bumper does it it go up and down any?
1976 FJ40 aka Yoda Monster
1996 Jeep XJ
Originally Posted by xdgt03 View Post
I removed mine. It is against federal law but so is being an illegal immigrant so...
postaldave is offline
post #7 of 8 Old 05-16-2010, 01:57 PM Thread Starter
cvorden
1987 YJ Wrangler
They are soaking now. Kinda makes sense that it would cause it but then again nothing on a YJ makes sense until you turn a wrench.
cvorden is offline
post #8 of 8 Old 05-16-2010, 03:07 PM
89CoolJeep
Junior Member
Honestly taking the front trac bar and driving safetly all depends on the truck. For my set up I leave front in and back out. On bumpy sharp turns I do have that jump off the ground feeling, and the sideways feeling. Also ever since its been off, on sharp accelerating turn one wheels goes up in the air
89CoolJeep is offline
Steering wheel sideways? jpschacht TJ Wrangler Technical Forum 10 03-15-2010 08:24 PM
Diehard Platinum Sideways Mounting? cyberiv TJ Wrangler Technical Forum 2 12-10-2009 12:31 PM
Pinion to T case sideways alignment??? Tim Shafer YJ Wrangler Technical Forum 2 08-23-2008 10:33 AM
Sideways 5 speed..... Elwood TJ Wrangler Technical Forum 3 09-09-2007 04:56 PM
05 TJ does sideways somersault downhill 87-05 TJ Wrangler Technical Forum 28 08-04-2005 06:20 PM
