That hissing noise - JeepForum.com
post #1 of 2 Old 09-17-2001, 08:49 AM Thread Starter
HJ
That hissing noise
Thanks to all for info on the vaccume lines -they do indeed seem to go to he vacuum motor on the front axle " as Jeeper Bill said "to slide the internal collar to engage the axles when in 4WD"
When I move the transfer case into 4WD, the "4WD" light does come on whether or not the tubes in the cab are sealed off (I've used some tape on them and this stops the hissing ...but should I leave the tape on or leave it off & put up with the hissing? - can any damage result by sealing the tubes off permanantly? seems OK at the moment!
Best wishes - Hwfa - new to YJ's
Hwfa
HJ is offline
post #2 of 2 Old 09-17-2001, 09:43 AM
JeeperJay
I would assume those tubes need to be connected to somthing. Where exactly are they located? I'll crawl under my dash and see if I can find where they go.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
shocks bad?????hissing noise brian10-2 TJ Wrangler Technical Forum 2 09-25-2009 12:17 PM
hissing wistle noise from under the jeep jeepy01 TJ Wrangler Technical Forum 3 08-18-2009 11:31 PM
Annoying hissing noise... jmkeo74 TJ Wrangler Technical Forum 8 03-10-2008 03:30 PM
Hissing noise when the brakes are applied, what is it?!! Ryan78786 TJ Wrangler Technical Forum 3 04-21-2007 11:02 PM
Hissing Noise at Shutdown dz1087 TJ Wrangler Technical Forum 15 07-12-2006 10:50 AM
