Highway rpm with 258, factory size street tires and stock 3.07 gears? - JeepForum.com
post #1 of 3 Old 10-08-2002, 06:44 PM Thread Starter
diggedyduh
I was wondering at what rpm range a stock 258 powered yj with 3.07 gears runs at highway speeds (60-70...please state what speed and rpms ) My logic behind this is that right now i have 31's with stock gears and 5th gear accellerates slowly and never gets past 1800 rpms at 65(bout top speed in 5th gear depending on the wind lol ), but 4th gear goes up to about 2500 rpms at 65 and accelerates easily of couse. well i am goin to 33s and am going to change gears eventually but was wonderin if now 4th gear would be at about the right rpms so id like to compare to a stock yj.
thanks
90 wrangler
33X12.5x15 Firestone Destination MT ( new and very beefy), 1.5" shackle lift, custom home brewed 2" suspension lift, 258 w/ a weber carb , debating on the Hei
diggedyduh is offline
post #2 of 3 Old 10-08-2002, 09:04 PM
Meister_jeep
compared to my jeep which is the same 258 and 3.07 gears but I only run 215/75/r15 wheels for now I check my speed a few minutes ago and your setup is right in the stock range so I wouldn't worry about that
1988 YJ 4.2l
__________________________________________________ __
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
FORD 8.8 WITH 4.10 GEARS, DISK BRAKES
33x12.50 GOODYEAR MT/R's ON AR767 15x8
CUSTOM STANLESS STEEL DISCO`s
JUICEBOX.
LED TAIL LIGHTS
$10 homemade POSILOCK
(IN THE WORKS THIS SUMMER)
-Custom front and rear bumpers
-HEI UPGRADE
-4.0 HEAD
-MIGHT TRY THE JEEP INJECTION KIT FROM WEBER
Meister_jeep is offline
post #3 of 3 Old 10-10-2002, 09:47 AM
BNKRPT WRNGLR
At speeds from 60 to 70 my rpm was 2000 rpm and with my 32's i was running 60 to 70mph at 2500. tip: if you need to accelrate fast to change lanes or to go faster put it back in 4th gear. it doesn't hurt the tranny I was told from a Jeep mechanic that 3rd 4th and 5th gear can go up to 3000 rpm before needing to shift
Nice Rigs Are Built Not Bought Unless It's The Rubicon Where It's Bought Built!
BNKRPT WRNGLR is offline
Big tires / stock gears... who's doing it? tjwrangler99 TJ Wrangler Technical Forum 22 03-23-2009 02:51 PM
Factory Rubicon rimes. What size tires fit. onlyme44 TJ Wrangler Technical Forum 2 03-04-2009 07:39 AM
what size are factory tires on a JK?? jeepin1995 JK Wrangler Technical Forum 7 12-06-2008 08:07 AM
Gears + Tires Size = What MPG? NotOfThisWorld TJ Wrangler Technical Forum 56 09-26-2008 08:35 AM
91 Wrangler with 456 Gears & 33" tires -- Long distance highway trip, is that ok? hustlepaintball YJ Wrangler Technical Forum 16 10-06-2006 11:05 AM
