highway performance - JeepForum.com
post #1 of 2 Old 04-22-2001, 08:14 PM Thread Starter
Nine5YJ
highway performance
hey-
i have a 95 YJ 4Cyl mostly stock except for a few things, and when i hit about 70-75Mph, over minor bumps and what not, my jeep will shake horibly until i drop to about 60. now ive had it to about 85mph safely with no shaking at all. is there anyway to prevent shaking by adding bigger tires or a lift? i know jeeps were not made for speed, but on some highways around here, if you dont keep up with the flow, you'll get rear ended. any input greatly appreciated! Thanks
Tom
95 YJ (slight mods)
95 YJ, 31 x 12.5 ProComp ATs / AR767 wheels, stock 4.10s, 2 1/2" Rough Country Suspension Lift, and huge rusty basketball sized drain holes.
Nine5YJ is offline
post #2 of 2 Old 04-22-2001, 08:54 PM
Tonka
2015 JK Wrangler
Start by having your tires rebalanced, and check your U-joints for play. If you have custom wheels, loosen the lugs, and retighten them with the wheels off the ground. torque all lugs to 105 ft. lbs.
Or lift it enough that all they hit is tire
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
Hawk Performance HPS High Performance Street Disc Brake Pads? NW Jeep TJ Wrangler Technical Forum 54 11-02-2011 10:54 PM
Rubicon vs. X - highway driving feel and performance? 76406 TJ Wrangler Technical Forum 32 09-26-2009 05:00 PM
performance and not performance shocks MODUS TJ Wrangler Technical Forum 4 12-02-2007 11:53 AM
99 4.0L highway performance magnato1 TJ Wrangler Technical Forum 6 08-03-2005 11:52 AM
2.5L need better highway performance WranglerYJ94 YJ Wrangler Technical Forum 2 02-24-2003 08:15 PM
