high steer for soa - Page 2 - JeepForum.com
post #16 of 18 Old 01-20-2012, 01:24 AM
timatoe
timatoe's Avatar
Originally Posted by lovett86 View Post
im thinking about just cutting and sleeving the drag link to extend it for now
I did this with mine, but I used a stock drag link from an XJ. I cut it basically in half eliminating excess length from the middle, beveled the two ends and butt welded it back together. Then I sleeved some square tubing over the entire thing. I had drilled various holes in the tube so I could rosette weld it to the drag link as well as at the ends....
Not the best pic, but you can see it here....
timatoe is offline
post #17 of 18 Old 01-20-2012, 09:24 AM Thread Starter
lovett86
i was thinking of doing the same with the drag link
lovett86 is offline
post #18 of 18 Old 01-20-2012, 09:26 AM Thread Starter
lovett86
Originally Posted by Apollo12227 View Post
The drag link should be as close to parallel with the axle as possible (horizontal). The higher the angle of the drag link, the more input the steering receives when suspension moves (bump steer).
okay, thats what i thought, thanks
will post up some more pics when i get it tacked into place
lovett86 is offline
High Steer rollover755 YJ Wrangler Technical Forum 15 12-16-2011 04:49 PM
High Steer TedderX_ TJ Wrangler Technical Forum 2 04-17-2010 08:23 PM
Do you have to do high steer... jbierschwale YJ Wrangler Technical Forum 10 01-07-2008 07:56 PM
High Steer Shrek TJ Wrangler Technical Forum 20 06-20-2007 10:59 AM
doing a SOA....what High steer kit? Jakesteads YJ Wrangler Technical Forum 14 09-12-2006 01:10 PM
