high steer for soa - JeepForum.com
post #1 of 18 Old 01-07-2012, 12:06 PM Thread Starter
lovett86
high steer for soa
what do u think of this high steer braket, a friend of mine made it for his yj and im thinking of going the same way
im only gonna be using the jeep for mudfest every year and the trails out at by buddys place so i was thinking this would be a good set up for me
lovett86 is online now
post #2 of 18 Old 01-07-2012, 12:12 PM
firefighter315
Is that mounted at only two points? I wanted both the tie rod and drag link moved, so I went with the RRO OTT kit. There are many other options for building your own though. I don't think I'd put my trust in a bracket that takes that kind of pressure and is critical to my safety that is depending on two mounting points only. Just my two cents.
My YJ Build Thread
firefighter315 is offline
post #3 of 18 Old 01-07-2012, 12:18 PM Thread Starter
lovett86
thats kinda what i was wondering, but im only gonna be wheeling in the trails, nothing extreme, no rock crawling or any thing like that
post #4 of 18 Old 01-07-2012, 12:21 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
^^^This^^^
To be reliable, it needs to be attached at more places than the two shown.
Like these 3 additional places here on top of the knuckle here:
Joe Dillard is offline
post #5 of 18 Old 01-07-2012, 12:23 PM Thread Starter
lovett86
did u just drill and tap those?
post #6 of 18 Old 01-07-2012, 12:23 PM
Joe Dillard
See this crack?
That'll eventually be the result if not attached in a more sound manner.
post #7 of 18 Old 01-07-2012, 12:25 PM Thread Starter
lovett86
i definatly see that, was just about to ask if u had any more pics
post #8 of 18 Old 01-07-2012, 12:26 PM
Joe Dillard
For the most part - yes.
You'll need to grind the natural knuckle rise down, so that the additional bracing seats properly against the knuckle.
post #9 of 18 Old 01-07-2012, 12:28 PM
Joe Dillard
That is NOT my bracket (the cracked one). I was just showing it for illustration purposes. It was on a friends Jeep.
I have lots of pics of the MORE steering I use to run.
post #10 of 18 Old 01-07-2012, 01:23 PM Thread Starter
lovett86
thanks man, im gonna have to do some more research, maybe i will see if i can find a used kit too
post #11 of 18 Old 01-07-2012, 02:16 PM
timatoe
timatoe's Avatar
The JB4X4 bracket is similar in design, but mounts at 5 points rather than two.
timatoe is offline
post #12 of 18 Old 01-07-2012, 04:10 PM
firefighter315
This is the casting ridge Joe mentioned grinding down to make the mating surfaces true.
For the RRO high steer bracket, you drill/tap for two points on top, then using extended hardware, use the three factory mounts that pass through and secure the unit bearing. That makes 5 points of attachment and the 6th point is the original tie rod mounting position that you drill out for, IIRC, a 7/8 grade 8 bolt. With those 6 points of attachment, I still welded both brackets for safe measure.
Here you can see two of the three that pass through the factory unit bearing mounts.
If you plan on using a bracket with only two mounts - even with "mild" trail use - I'd suggest keeping your old drag link with you so you can mount it back up and get off the trail if/WHEN it breaks off.
My YJ Build Thread
post #13 of 18 Old 01-08-2012, 06:50 AM Thread Starter
lovett86
thanks for the good info
post #14 of 18 Old 01-19-2012, 06:58 PM Thread Starter
lovett86
so this is where im at for the high steer
im thinking about just cutting and sleeving the drag link to extend it for now
i still have to drill the holes in the bracket and spidle and tap the bracket, have to drill the taperd hole in the bracket for the drag link and weld it on, what angle is best for the drag link when u have it mounted?
post #15 of 18 Old 01-19-2012, 09:05 PM
Apollo12227
The drag link should be as close to parallel with the axle as possible (horizontal). The higher the angle of the drag link, the more input the steering receives when suspension moves (bump steer).
Apollo12227 is offline
High Steer rollover755 YJ Wrangler Technical Forum 15 12-16-2011 04:49 PM
High Steer TedderX_ TJ Wrangler Technical Forum 2 04-17-2010 08:23 PM
Do you have to do high steer... jbierschwale YJ Wrangler Technical Forum 10 01-07-2008 07:56 PM
High Steer Shrek TJ Wrangler Technical Forum 20 06-20-2007 10:59 AM
doing a SOA....what High steer kit? Jakesteads YJ Wrangler Technical Forum 14 09-12-2006 01:10 PM
