Quantcast high steer kit needed? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > high steer kit needed?
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 11-20-2009, 08:46 PM   #16
blue-monster
Originally Posted by Apollo12227 View Post
The rocky road highsteer kit is the best kit i've EVER seen... I own it and it made my steering BETTER THAN STOCK... I'm running 36" tires, Spring Over Conversion (4" of lift) along with 2.5" springs, and 1 1/4 shackles... So more or less 8 total inches of lift. A dropped pitman arm simply isn't enough, i've got a drop pitman arm WITH my high steer kit and this allowed me to bolt my skid plate directly to the frame, I have no spacers (transfer case drop)what-so-ever...
Although the rocky road kit is expensive as heck... it was worth every single penny in my case... I love it to death, wouldn't give it up for anything.
but i have 11" lift do you think this bracket will gonna work with me?
blue-monster is offline   Reply With Quote
Old 11-20-2009, 09:46 PM   #17
Apollo12227
Absolutly, like I said, mine is better than stock right now... 11" of lift wont be a problem for this kit, it puts your entire tierod above your leaf springs. If you REALLY really really were worried about it, you could easily make yourself a plate to go between the knuckle and the bracket... I know you said your not really into fabrication too much, but it would be pretty easy processess bolting a rectangle plate to lift the bracket up even further.
Again, I would say that the rocky road outfitters lift will easily handle 12" of lift... Any more than that, and I think you would hit issues, but 11" really shouldn't be a problem. You will however, have to fabricate a bracket for the steering stableizer.
I'm telling you man, its worth every penny, with tax shipping and handling you get the beefier tierod with the huge aftermarket tie rod ends and end up with $525.00 almost exactly... I know its expensive, but as soon as I purchased this kit, every one of my YJ buddies got the same one.
Go for it, you wont be disapointed! If your too nervious about it, I suggest looking for a high pinion dana 44, there were a few available that had the steering knucle tie rod mount at the top... But this kit is definatly the way to go.
Apollo12227 is offline   Reply With Quote
Old 11-20-2009, 09:48 PM   #18
Apollo12227
The only other thing I would advise you worry about, is what tires you are running with your 11" of lift. Anything bigger than 40's is too rediculous for the Dana 30... I run 36" tires with my 8" lift and dont have any issues, but you will be wasting your money throwing doughnuts like 44's on your heep dana 30.
Old 11-21-2009, 01:35 PM   #19
blue-monster
that is my problem.. i need help
Old 11-21-2009, 01:49 PM   #20
bigbelman2009
2 bracket for bothe side left and right 160$ right? and thanx aloot
no you only need one for the passenger knuckle.
i will put some pics up in a sec
bigbelman2009 is offline   Reply With Quote
Old 11-21-2009, 01:52 PM   #21
bigbelman2009
knuckle
pitman arm
i put on a drop pitman arm with it and my drag link is just about parallel with my tie rods
Old 11-21-2009, 03:46 PM   #22
Apollo12227
He has an 11" lift... A drop pitman arm will only recover about an inch and a half of that. As for replacing ONE OR BOTH KNUCKLES... The Rocky Road Highsteer Kit comes with both, the reason you would want both, is because it completely lifts the tie rod and drag link above your leaf springs. Which is amazing because rocks will never again have access to your tierod before going through your leaf springs and entire front axle.
Now, Just replacing the Passanger side is fine, Tereflex makes a complete passanger side replacement kit HOWEVER its still pricy and still leaves your tierod half a foot above ground.
For someone with 8+ inches of lift, moving ALL of the stearing geometry north is the best idea... In my opinion at least and all of the other 8+ lift runners around where I live would agree.
Old 11-21-2009, 03:59 PM   #23
blue-monster
Originally Posted by kloppk View Post
When I did my SOA I used the Rocky Road YJOTT High Steer kit.
from where you got this bracket?? i want same this
Old 11-21-2009, 06:16 PM   #24
timatoe
Jello Puddin'
timatoe's Avatar
The rocky road kit is great, but there are thousands of Jeepers out there running the JB4X4 bracket with no problem. Half of what your saying here has no relevance to the mans question.
timatoe is offline   Reply With Quote
Old 11-21-2009, 06:27 PM   #25
crb577
I noticed when I put my 35's on that I had a little more steering slop than I wanted with pretty much the exact setup as you have. I ordered the JB4X4 bracket and it works very well for my setup. That rocky road setup I have seen on multiple rigs on here and it looks like a very complete setup for a decent price as well. I used a factory pitman arm with the JB4X4 bracket and drag link this is it at max flex
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,5" BDS, homemade greasable boomerang shackles, SS braided lines, rubicon flares, 1" prothane body lift, 35" TrXus M/T, smitty built XRC, armor and a paint job soon to come.
crb577 is offline   Reply With Quote
Old 11-21-2009, 06:35 PM   #26
YJames90
aka Jamesx2
YJames90's Avatar
No just the pass side
My 2.5 to 4.3 swap thread
http://www.jeepforum.com/forum/f12/4-3-swap-has-finally-begun-1237704/
If your going to talk about me talk to me
YJames90 is offline   Reply With Quote
Old 11-21-2009, 06:37 PM   #27
YJames90
aka Jamesx2
YJames90's Avatar
Nice set up
Old 11-21-2009, 06:50 PM   #28
blue-monster
[QUOTE=jamesx2;8333755]No just the pass side
[/QUOTE
can you give me the site for the bracket? i want same this bracket ,, can i use my link bar or i have to change it?
Old 11-21-2009, 06:55 PM   #29
timatoe
Jello Puddin'
timatoe's Avatar
Here's their site, The JB Raised Steering Bracket
I noticed that is says in your profile your in Bahrain. The JB4x4 site says.....
Originally Posted by JB4X4 Site
Note: We are currently shipping to U.S. addresses only.
You may need to have it shipped to someone in the states who could then ship to you.
Old 11-21-2009, 07:00 PM   #30
blue-monster
my friend there in california i'll tell him to send me this thanx aloot for you help guys
Glock Forum
