#1 | ||
Yota Recovery Specialist
high steer kit needed?
'90 I6 258 w/ Weber 32-36 Carb. 32" BF M/T's with cragar rims 5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear. ~Enjoy>>> http://youtube.com/watch?v=nQCIXoBqpc0 JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin OMNIPOTENCE...gotta get me some of that |
#2 |
anyone have any info about this?
#3 |
High steer couldnt hurt the Jeep. But, I think that you will be ok, unless you are going SOA. I think you will need a drop pitman arm though.
'91 YJ. 4.0 TF999, D300 w/ 4:1, twin sticks. Chevy D44 front, 4.10's, spooled, Yukon 4340 shafts w/ super joints. Warn premium lock outs, High steer, ram assist. Dodge D60HD rear, 4.10's, welded, disc brakes. SOA front w/ RE 1.5" SOA leaf packs. Custom 4 link rear w/16" fox air shocks, stretched to 110". 38x12.5x15 TSLs on crager Nomads w/ DIY beadlocks. Tolly Fab Tube fenders, rocker gaurds, cage. 15gal stainless steel fuel tank. |
#4 |
you dont have to go highsteer but you can do a tie rod flip with inserts from
goferit products. you will still need to do a little fab work and the d30 steering arms are low on the knuckle but it will raise it up.
"We'll get out of this disaster in time for the next one" "I'm done recomboobulating the energy-mo-tron" 88 YJ, 350/350 Chevy, Twin Stick Dana 300 with JB 32 spline rear output, 6.5" lift, Front Scout II Dana 44 w/Yukon 4340 shafts, trac loc, 4.27's, Warn Premium Hubs, flipped YJ Tie Rod, Ford F150 front calipers, Rear Scout II Dana 44 w/Alloy 4340 shafts, HD RPT retainer plates, 4.27's True trac, Steeltech Disc brakes, Cage upgrade, B&M Prostick Shifter, Custom Fabbed tire, gas, jack carrier, 3/8 angle rear bumper, clevis's all around, old & reliable rep8000 winch. Flood lights. loud stereo. 35x12.50 swampers and a bunch of other stuff |
#5 |
SOA or 5 in 4wd lift?
this thread for reference. I don't *THink* it would be needed. at very minimal, drop pitman arm. maybe tie rod flip as mentioned above, that's probably a good idea. anybody w/ 5" lift w/ experience on this? if it's needed, not needed. Pics. ![]() |
#6 |
I run the BDS 4.5 with 4wd shackles that say 1" but are less, run the flipped tie rod setup with a stock pitman arm. I'll try to get a pic here...
#7 |
here are some photos. good thing I am bored i guess.
this is sitting flat in my driveway granted the arms on my outer knuckles are higher than a d30 but you get the idea.
#8 |
When I did my SOA I used the Rocky Road YJOTT High Steer kit.
#9 |
i have never seen that high steer kit!!! how much does that run???
#10 |
I'd be intrested as well. Where did you pick that kit up at?
#11 |
As mentioned its sold by Rocky Road Outfitters.
Here is the link to their web page with the system description, features and pricing. http://www.rocky-road.com/yjott.html It's for use on the stock YJ Dana 30 axle & steering knuckles. ![]() The price listed is: $479 |
#12 |
from where you get the bracket? it is custom or original kit?
#13 |
93 YJ low n light |
#14 | |
#15 |
Dream,Eat,& Sleep... HEEP
The rocky road highsteer kit is the best kit i've EVER seen... I own it and it made my steering BETTER THAN STOCK... I'm running 36" tires, Spring Over Conversion (4" of lift) along with 2.5" springs, and 1 1/4 shackles... So more or less 8 total inches of lift. A dropped pitman arm simply isn't enough, i've got a drop pitman arm WITH my high steer kit and this allowed me to bolt my skid plate directly to the frame, I have no spacers (transfer case drop)what-so-ever...
Although the rocky road kit is expensive as heck... it was worth every single penny in my case... I love it to death, wouldn't give it up for anything. |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| TJ high steer kit | V-8unlimited | TJ Technical Forum | 28 | 12-31-2009 10:24 AM |
| AEV JK high steer kit | USAntigoon | JK Technical Forum | 17 | 04-04-2009 05:27 PM |
| high steer | deryk111 | TJ Technical Forum | 5 | 02-16-2009 10:00 PM |
| High Steer Kit..? | UTIJeeper | TJ Technical Forum | 4 | 07-20-2007 12:32 AM |
| doing a SOA....what High steer kit? | Jakesteads | YJ Technical Forum | 14 | 09-12-2006 01:10 PM |
The time now is 11:42 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
