High Oil Pressure/Cap Leak - JeepForum.com
post #1 of 4 Old 07-01-2011, 08:14 PM Thread Starter
jth0033
1987 YJ Wrangler
Alrighty I've done some research but haven't come up with anything that was similar to mine. So here goes, figure I will fill everyone in on some information about my rig first. As of late I've had trouble with my oil pressure gauge. I replaced both the oil pressure switch and oil pressure sender. Recently I have done a motorcraft swap and also replace the valve cover gasket. This week I took a trip down to OBX and found that my oil pressure gauge is pegging at high speeds, causing a leak at the oil cap. Seems the oil has no where to go and leaks from the cap. How can I fix this?? Any help is greatly appreciated. If pictures of my setup are needed I can post them also. Thanks
jth0033 is offline
post #2 of 4 Old 07-01-2011, 08:30 PM
4.7stroker
OK high oil pressure does not translate into high crank case pressure.
I would go through your PCV system to make sure everything is clear and working as it should.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 4 Old 07-02-2011, 06:45 PM Thread Starter
jth0033
1987 YJ Wrangler
Looks like I will have to check it all out tomorrow. Could it just be that I wired it wrong? I did recently replace the pvc valve too.
jth0033 is offline
post #4 of 4 Old 07-02-2011, 06:46 PM Thread Starter
jth0033
1987 YJ Wrangler
and by wired i mean ran the hoses incorrectly somehow
jth0033 is offline
Oil Pressure High (very high) GreenRenegade YJ Wrangler Technical Forum 17 12-05-2010 10:45 PM
Restart Idle High and High Oil Pressure bringbackphish YJ Wrangler Technical Forum 2 12-09-2008 08:46 PM
high oil pressure joe's_yj YJ Wrangler Technical Forum 1 05-20-2007 08:44 PM
Power steering high pressure hose leak todnshay YJ Wrangler Technical Forum 4 12-21-2004 06:56 AM
Very high oil pressure BigD1634 YJ Wrangler Technical Forum 3 11-28-2001 06:40 AM
