High Oil Pressure - JeepForum.com
post #1 of 13 Old 04-26-2007, 06:10 PM Thread Starter
Tom Kuhn
High Oil Pressure
I'm having an issue with my son's 92 Wrangler 2.5. He bought it 3 years ago, and it's always running high on pressure. It has just recently begin to climb. It has about 92,000 miles. With the engine warm, ideling showed about 65 Psi. Driving on the interstate took the pressure beyond 80 PSI. The oil is never low, and changed every 3000 miles. The oil currently has less than 100 miles on it. Currently using 10W30.
I changed the sending unit, pressure remained the same. I then connected up a mechanical gauge, the pressure read pretty much the same (3-4 lb difference).
I checked the ccv lines on the outside, no clogs or dirt. I gave in and dropped the pan, and changed the oil pump.There was no sludge, dirt or filings in the pan. Ideling warm now goes to about 55Psi, and the 2500 rpm still almost goes to 80.
What's next?
Tom Kuhn is offline
post #2 of 13 Old 04-26-2007, 06:15 PM
Sahara88
Sahara88's Avatar
I think that might be normal, My oil pressure gage is always past the 6... Im not sure if it's normal, but the way i see it is it's better than having low oil pressure.....
Sahara88 is offline
post #3 of 13 Old 04-26-2007, 06:24 PM
93YJNewf
Mine's the same too.....just thought is was normal
93YJNewf is offline
post #4 of 13 Old 04-26-2007, 06:55 PM
jay-h
What's next?
If you turn on the key without starting the engine, does it read zero?
You can replace the sender for a few bucks, probably not a bad idea (my sender was bad when I bought mine and read ridiculously high. Happily the oil pressure is still ok with the new sender.
jay-h is offline
post #5 of 13 Old 04-26-2007, 07:14 PM
RAZORBILL
RAZORBILL's Avatar
2014 JK Wrangler
My 95 4 banger reads 40 at idle and just shy of 60 at 2500 rpm (107k). That's with a new sending unit a couple weeks ago. Not real sure what "normal" is. I'm using Mobil 1 10w-30...
Al
RAZORBILL is offline
post #6 of 13 Old 04-26-2007, 07:15 PM
Canadian89yj
YJ Wrangler
mines off the charts too...
Canadian89yj is offline
post #7 of 13 Old 04-26-2007, 07:42 PM Thread Starter
Tom Kuhn
It does read zero, I just changed the sending unit 2 weeks ago. I even confirmed the readings with a mechanical guage. I think the readings are ok.
Thanks for the suggestions.
Tom Kuhn is offline
post #8 of 13 Old 04-27-2007, 04:21 PM
Sahara88
Sahara88's Avatar
Is it normal to be past "6" all the time??
Sahara88 is offline
post #9 of 13 Old 04-27-2007, 06:49 PM Thread Starter
Tom Kuhn
Once it warms up, the Idle drops down to 50 - 55 psi. As you drive, depending on your RPMs, the pressure goes up and down.
Tom Kuhn is offline
post #10 of 13 Old 04-27-2007, 07:47 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
sounds like my situation too. never really bothers me as long as I have pressure.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #11 of 13 Old 04-27-2007, 10:22 PM
daciuk55
The stock owners manual for the 4.0 at least says that normal should be between 20 and 65
1) 1993 YJ AX-15-, ford 8.8 LSD/ dana 30 4.10s,3.5" Black Diamond,5/8 " M.O.R.E Shackels,AA SYE/Tom Woods rear CV Shaft,33x10.50 BFG Mud Terrains
2)1998 XJ Sport AX-15- 1 3/4" Budget Boost- Tomken Gas tank skid-30x9.50 BFG All Terrains
3)1998 Xj sport 2 door ax-15- bone stock
4)1964 cj-5a
daciuk55 is offline
post #12 of 13 Old 04-27-2007, 10:39 PM
Monk89 94 I4
mine has never read below 45, and is always 60-75 depending on my rpms..
Will
94 was a great year for the yj, 2006 was a great year when i put the sport cage in it...
Monk89 94 I4 is offline
post #13 of 13 Old 04-28-2007, 08:14 AM
bogger jeep
man i wish i had that kind of problem. mine runs good until it warms up then drops to 10. its a wheeling only rig so i just drive it. when it blows i'll swap in a 4.0 efi
bogger jeep is offline
Oil Pressure.... too high? MikeyJ YJ Wrangler Technical Forum 13 05-09-2009 10:41 PM
Restart Idle High and High Oil Pressure bringbackphish YJ Wrangler Technical Forum 2 12-09-2008 08:46 PM
high oil pressure Sunvista TJ Wrangler Technical Forum 5 07-22-2008 05:03 PM
oil pressure high heapofjeep YJ Wrangler Technical Forum 9 03-14-2006 07:41 AM
Very high oil pressure BigD1634 YJ Wrangler Technical Forum 3 11-28-2001 06:40 AM
