High idle then dies 88 yj 4.2 - Page 6 - JeepForum.com
post #76 of 85 Old 12-19-2011, 03:11 PM Thread Starter
JeepJon15
Bank account is $100 lighter, but i got a duralast battery. I just put it in along with new terminal clamps. Fired up, idling well. I'm going to get gas now, so this will serve as a test drive. Wish me luck.
JeepJon15 is offline
post #77 of 85 Old 12-19-2011, 03:14 PM
oldtime_ironman
lets see what happens, sounds good so far... make sure to check if the lights stay at the same brightness too, OK?
Now that you got the stuff, it makes sense to start doing the fine-tuning - like Old4X says, a vac gauge is indispensible for putting the fine-tune on things.
oldtime_ironman is offline
post #78 of 85 Old 12-19-2011, 03:37 PM Thread Starter
JeepJon15
And that was the best its ever driven. No more miss, hesitation after i push the gas, or dimming head lights. If i knew $100 bucks for a battery would show that much improvement i would have bought it with a smile on my face. Though i will credit some of the improvement to the carb fix.
I also picked up a vacuum gauge and spark plug gapper. That is on the list for either tonight if i have time or tomorrow.
Only thing its doing now is: When started it idles in park at around 1000rpm. In drive it kicks down to about 850-900. Haynes says 850 in park is ideal, so im just on the high side. Once i drive it and go back into park, the idle shoots up to about 1500 rpms. Will this likely be corrected once i tune the carb with that gauge?
You guys' help made all the difference. Really, if i were on my own the jeep would still be rotting in the driveway. I dont want to jump the gun, but i think i might be able to drive myself to work tomorrow!! haha
post #79 of 85 Old 12-19-2011, 03:45 PM
oldtime_ironman
Yep, once you go thru the fine-tune with the vac-gauge and timing, etc. It should settle right into perfect. Also with properly gapped plugs. Enjoy the drive to work!
post #80 of 85 Old 12-19-2011, 03:56 PM Thread Starter
JeepJon15
Thanks so much, pretty excited about being able to drive again. If youre still on i have one more quick question. Its dark out, and the garage is occupied. Would it hurt to drive like this tonight and tomorrow morning? Less than 50 total miles, and then fine tune/set gaps tomorrow?
Should i get my alternator checked at autozone? Only reason i ask is because i'm worried that may have drained and killed the other battery. It was getting old, 7-9 years. I'm just being cautious because i dont want to ruin the new battery.
post #81 of 85 Old 12-19-2011, 03:59 PM
oldtime_ironman
It would be an Excellent idea to check the alt possibly tonight if you can. I was worried about that too. It shouldn't hurt it to drive with the tuneing a bit off. Maybe kill your MPG's or make it weak on the highway, but it wouldn't actually hurt it permanently.
post #82 of 85 Old 12-19-2011, 04:06 PM Thread Starter
JeepJon15
Hah, that alt better be good or so help me...
Thanks man, i'll try to get over there tonight, and just do the tuning tomorrow.
post #83 of 85 Old 12-20-2011, 09:53 AM Thread Starter
JeepJon15
II just went out and tuned the carb with the vacuum gauge. I was already pretty close, but i got it to hover right in between 20 and 21. Still wants to stall when i put it in gear straight out of park if i have my foot on the brake. If i put it in drive and dont hold the break it will idle forward and then i can hit the brakes and it is usually fine.
I didnt have time to gap the plugs today, gotta be to work in an hour. I'll get that done tonight time permitting. Just wanted to post the progress, its still running well besides that small problem.
edit: I'm also running it with the timing closer to 10*, just because it seems to run better that way. Maybe after i set the plug gaps it will give me a hotter spark so i can take it back down to 8.
post #84 of 85 Old 12-20-2011, 08:19 PM
Old4X
1990 CJ7
Sounds like you about got it. Good job, enjoy the ride.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #85 of 85 Old 12-22-2011, 09:37 AM Thread Starter
JeepJon15
Thanks so much. I learned a lot from you guys.
On a side note, and dont feel obligated to answer. I posted a new thread for this, but i thought maybe one of you two may know the answer.
My passenger side break light and turn signal werent working when i had the headlights on after replacing the driver's side housing. The bracket was all rusted out, and it was having basically the same issue described above before replacement, and the passenger side was working fine.
Anyway, i went out and pushed the wire harness under the steering column together real good (didnt feel loose at all) and swapped the bulbs from driver to passenger side. Now everything is working fine.
I hadnt checked on it since battery replacement a couple days ago, could this have solved it? I just want to make sure the problem doesn't come back. I already got a warning for the driver's side brake light being out a couple months ago. Also, my windshield wipers work sporadically, maybe unrelated but cant hurt to add that extra info.
Thanks guys, and like i said, i posted that in a new thread so if you don't have time to solve my problems anymore its no biggie!
4.2 , carb , hei , idle , YJ
2004 TJ 4.0 High Idle after Drive, but then normal idle greenjeepsrule TJ Wrangler Technical Forum 6 11-07-2012 11:52 AM
very low idle then dies. failure2stop TJ Wrangler Technical Forum 3 05-21-2010 09:22 AM
High Idle, High Pitched Whine, Black Soot PolakX TJ Wrangler Technical Forum 6 02-15-2010 07:34 AM
High idle 2k rpm, idle jumping on braking - Moab in jeopardy AndrewMuadDib TJ Wrangler Technical Forum 9 09-06-2009 10:19 AM
Help! 4.0 dies when in idle 4LiterFury2010 TJ Wrangler Technical Forum 2 08-17-2009 03:15 PM
