High Idle problem - JeepForum.com
post #1 of 9 Old 05-22-2013, 02:11 AM Thread Starter
demonz0
High Idle problem
I recently did my exhaust system and since then I have a high idle. Runs around 1400 RPM at all times now when it ran at 700rpm idle before. The air box did come out to access the manifold flange.
Before than I also hydro locked my jeep but had fixed it.
99 Cherokee 4.0L | 4.5in Lift | 33x12.5
94 YJ 4.0L | 4in RC Lift | 33x12.5
demonz0 is offline
post #2 of 9 Old 05-22-2013, 02:31 AM
billybooster2
1983 CJ8
sounds like vacuum leak somewhere...broken / cracked hose somewhere?
billybooster2 is offline
post #3 of 9 Old 05-22-2013, 07:17 AM
102joe
A bad T. P. S. will do that too , some time you can pull it off and clean it , and it will clear up . Although it is pretty likely you disturbed a vacuum line while working on the exhaust , like Billy said . you can spray carb cleaner around the lines to try and fide it .
REAL JEEPS HAVE LEAF SPRINGS
NO REALY ,, IT IS HIP TO BE SQUAIR
102joe is offline
post #4 of 9 Old 05-22-2013, 07:17 AM
Que89YJ
x2 with Billy vacuum leak. Use carb cleaner and spray around listening for any idle change.
Que89YJ is online now
post #5 of 9 Old 06-02-2013, 04:28 AM Thread Starter
demonz0
Haven't gotten around to looking but have noticed a few other things about it. It starts really rough and as the temperature of the engine goes up so does the idle. Change your opinions or not?
Also I just spray the carb cleaner along the lines and connections?
demonz0 is offline
post #6 of 9 Old 06-02-2013, 08:03 AM
102joe
Vacuum leak , engine will run warmer with high idle . Spray carb cleaner around the suspicious hoses or any where air could be sneaking into the intake . When the cab cleaner goes in inted of air the engine will rev up .
102joe is offline
post #7 of 9 Old 06-02-2013, 08:53 AM
Que89YJ
spray every place you have a vacuum line. the pvc hose, manifold, and brake booster especially.
Fault codes:
Mean Max pics of everything:
No Start:
post #8 of 9 Old 06-02-2013, 08:54 AM
Que89YJ
I bet your manifold since you just did the exhaust.
Fault codes:
No Start:
post #9 of 9 Old 06-02-2013, 11:52 AM
tchoberg
1987 YJ Wrangler
The problem will be no doubt be related to something you did when changing the manifold. ( the `whatever u touched last rule`). Vacuum leak is the prime suspect as was pointed out earlier, so get the carb cleaner and find it the easy way. By the way, an UNLIT propane torch works also.
If it ain't broke, don't fix it - Don't worry, something will break soon enough for you to fix.
tchoberg is offline
