High idle. Just swapped my 2.5 TB for a 4.0 TB - Page 2 - JeepForum.com
post #16 of 23 Old 01-19-2012, 07:11 PM Thread Starter
ROTTEN
Sprayed all around with carb cleaner and no difference
Installed a new Tps no difference
Reset the computer no difference
BUT when I turn the wheels while idling the rpms quick jump up 600 and back down
What is that?
Tomorrow im putting the 2.5 tb back on
ROTTEN is offline
post #17 of 23 Old 01-19-2012, 09:35 PM
GrantYJ
The jump in idle comes from the computer. It's the same mechanism that makes your idle jump when you turn the air conditioning on.
As for your high idle, I agree with the previous poster that it probably is a result of you not opening up the hole in the intake manifold. I don't see the point in putting on a 4.0 TB if you don't open up the intake. You won't flow any more air (which is the whole point of the swap). More airflow = more HP.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #18 of 23 Old 01-19-2012, 10:13 PM Thread Starter
ROTTEN
Fair enough!
Off she goes tomorrow
ROTTEN is offline
post #19 of 23 Old 01-19-2012, 10:26 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
I did nothing to my manifold, that is not the problem.
Back Road Jeepin
BackRoadJPin is offline
post #20 of 23 Old 01-19-2012, 10:55 PM
BackRoadJPin
1995 Wrangler
Give this write a read and see if it is of any help.
What sensors do I keep from the 2.5. Which ones do I transfer over from the 4.0
you can transfer the TPS from the 2.5L but seems that they are the same between the 2, to be safe since you know yours is working I would do it anyway.
for the IAC (also known as AIS) you _need_ to use from the 2.5L both the plunger with the motor (sometimes referred to as the solenoid) and the housing that is bolted with 4 tamper proof bolts to the t/b - you should just take those 4 bolts out and transfer the whole thing over, but you'll need the proper torx bit with a hole in the center - they have a ton of thread lock on and are hard to take off, so make sure you don't strip the torx teeth off of it or you'll need to come up with some creative way to take them off afterwards.
if you have the MAP sensor on the t/b (TJ) then you can keep the 4.0L one if it's on there (it's the same as the 2.5L), but again this is if you know for sure it's good.
There are measurable gains to be had.
make sure you changed over the AIS/IAC housing if I remember now that was the problem with my high idle. I just remember I had to play around with the swapped items reset the computer drove it around for a little bit and it worked great.
Back Road Jeepin
post #21 of 23 Old 01-20-2012, 09:26 AM Thread Starter
ROTTEN
Ok we can let this subject sleep the rest of the winter. 2.5 is back on and it's running fine
Few thoughts
I did not change the iac housing. I didn't understand until I took the tb off what the housing was
Also I did not grind the intake
So one of those two things is the culprit
One big change is loss of power. The 4.0 tb Definantly makes a difference.
ROTTEN is offline
post #22 of 23 Old 01-20-2012, 09:57 AM
SnowYJ
1988 MJ Comanche
So power increase?
I go to college and I drive a Jeep.
SnowYJ is offline
post #23 of 23 Old 01-20-2012, 10:06 AM Thread Starter
ROTTEN
The power increase is noticeable
I really suggest it. 75 in 5th with new 32s. Before I could barely do 65
ROTTEN is offline
2004 TJ 4.0 High Idle after Drive, but then normal idle greenjeepsrule TJ Wrangler Technical Forum 6 11-07-2012 11:52 AM
High Idle, High Pitched Whine, Black Soot PolakX TJ Wrangler Technical Forum 6 02-15-2010 07:34 AM
High idle 2k rpm, idle jumping on braking - Moab in jeopardy AndrewMuadDib TJ Wrangler Technical Forum 9 09-06-2009 10:19 AM
high idle - cleaned tb, now higher idle! clarkvstewart YJ Wrangler Technical Forum 7 10-05-2008 10:48 AM
Swapped Mustang seats sit too high - what's lower?? bwiencek YJ Wrangler Technical Forum 0 01-03-2007 12:53 PM
