High idle. Just swapped my 2.5 TB for a 4.0 TB - JeepForum.com
post #1 of 23 Old 01-18-2012, 05:22 PM Thread Starter
ROTTEN
Just did the swap Monday. Upon startup when cold it rpms at 2100 then drops down after a minute
Will this hurt the engine? It's supposed to be 5 when I leave tonight
We re used the iac and Tps from the 2.5
Ground the tab on the 4.0 tb off
New gasket for the tb
Anyone have this experience? I've driven about 20 miles since the swap
More power but the high rpms bother me
Also it seems my temp is running hotter now
I'm concerned that it will hurt the engine upon start up
ROTTEN is offline
post #2 of 23 Old 01-18-2012, 05:32 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
I had the exact same issue several years ago, if I recall I cleaned things up really well, and I used the same parts as you did to remedy the problem. Make sure everything is sealed nicely and that everything is clean and working proper.
Back Road Jeepin
BackRoadJPin is offline
post #3 of 23 Old 01-18-2012, 05:41 PM Thread Starter
ROTTEN
Yeah it's all sealed up
BUT the 2.5 parts were very dirty
Iac had soot and oil on it and the Tps was the same
When they were on the 2.5 tb I was getting an idle of 1600 at start up and stumbling until the engine warmed up
Should I replace these two items?
ROTTEN is offline
post #4 of 23 Old 01-18-2012, 06:16 PM
BackRoadJPin
1995 Wrangler
I just cleaned them really good, and I reset the computer as well just in case, mine would not idle down for the longest time. In fact when I first swapped it all over the idle ran straight up to redline. Clean everything up, while doing so disconnect the battery to let the computer reset. It was when mine jumped to redline that I realized I had to swap some of the 2.5 parts back over.
Back Road Jeepin
post #5 of 23 Old 01-18-2012, 06:29 PM Thread Starter
ROTTEN
Hmm. I never took the battery cables off. Do you think that is a big step I should do? How long should they stay off?
ROTTEN is offline
post #6 of 23 Old 01-18-2012, 07:14 PM
BackRoadJPin
1995 Wrangler
I don't know if it is a big step or not, but it can't hurt to give it a try especially since it will take a few minutes to pull things apart and clean them. Disconnect +/-
Back Road Jeepin
post #7 of 23 Old 01-18-2012, 07:24 PM Thread Starter
ROTTEN
The tb and sensors are clean. I did the reset
When I restarted it it went to about 1700
Drove around for a bit and came back and restarted. Now the rpms jump to 2400 but go down quick because it's warm
Arg. I might put the 2.5 tb back on it
ROTTEN is offline
post #8 of 23 Old 01-18-2012, 08:09 PM
BackRoadJPin
1995 Wrangler
Sorry Rotten I don't have any other ideas for you, maybe someone else can speak up.
Back Road Jeepin
post #9 of 23 Old 01-18-2012, 08:33 PM
dmblair
I put the 4.0 on mine for awhile and did exactly everything you did. Same thing happened. Idled high for awhile when first starting it after it was warmed up and then it would go back down. That drove me bat$hit crazy cuz I could never figure it out. Threw the 2.5 body back on and it works fine. Wonder if it has something to do with the diameter of the intake not matching the throttle body. I'm assuming you didn't mill the intake for for the larger throttle body right? That was the only thing I could think of that might have an effect on the idle?!?!
dmblair is offline
post #10 of 23 Old 01-18-2012, 10:03 PM Thread Starter
ROTTEN
I didn't grind the intake.
I'm putting the 2.5 back on. Then I'll deal with the stumbling. Spring I'll fool with the 4.0 tb
Just too damn cold out!
ROTTEN is offline
post #11 of 23 Old 01-18-2012, 10:44 PM
jode
Crazy, Cuz that is exactly what my 2.5 needs. Right now I have to keep the throttle on in the mornings to keep it running, then, once it warms up I can let off the throttle and it will ease on down to about 1,000 rpm. Maybe I should do a 4.0 throttle body and it sounds like all that will be automatic
Hung like Einstein and smart as a horse...
90 YJ, 2.5L, 5-speed
jode is offline
post #12 of 23 Old 01-18-2012, 11:03 PM Thread Starter
ROTTEN
It really sOunds like we both need new idle air control motors
ROTTEN is offline
post #13 of 23 Old 01-19-2012, 12:29 AM
jode
Mine's brand new (my IAC that is)
Is there some sort of temperature sender that interacts with the IAC that may be bad on both of ours?
jode is offline
post #14 of 23 Old 01-19-2012, 12:49 AM
BackRoadJPin
1995 Wrangler
have you tried using the 4.0 IAC? Interchange them see what happens. I did this 4-5 years ago, and I know I sorted it out with the parts and sensors from the two throttle bodies. It turned out great and gave me a little more pep. However moving to the Seattle area at sea level made just a little more difference.
Back Road Jeepin
post #15 of 23 Old 01-19-2012, 10:46 AM
Que89YJ
2 things. A battery reset to force a relearn and a can or carb cleaner to check for vacuum leaks.
Que89YJ is online now
2004 TJ 4.0 High Idle after Drive, but then normal idle greenjeepsrule TJ Wrangler Technical Forum 6 11-07-2012 12:52 PM
High Idle, High Pitched Whine, Black Soot PolakX TJ Wrangler Technical Forum 6 02-15-2010 08:34 AM
High idle 2k rpm, idle jumping on braking - Moab in jeopardy AndrewMuadDib TJ Wrangler Technical Forum 9 09-06-2009 11:19 AM
high idle - cleaned tb, now higher idle! clarkvstewart YJ Wrangler Technical Forum 7 10-05-2008 11:48 AM
Swapped Mustang seats sit too high - what's lower?? bwiencek YJ Wrangler Technical Forum 0 01-03-2007 01:53 PM
