high idle - JeepForum.com
post #1 of 6 Old 08-01-2011, 08:11 PM Thread Starter
jlegan
high idle
I am having an issue with my jeep idling at 1200-1500 rpm. The idle adjustment screws are almost all the way out and there are no apparent vaccumn leaks, is there anything else I should look at or do
jlegan is offline
post #2 of 6 Old 08-01-2011, 08:57 PM
4.7stroker
The idle screws you are playing with are the idle mixture screws. These adjust the idle mixture not the idle rpms.
Look on the side of the carb you will find a single rpm adjustment screw there.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 6 Old 08-01-2011, 09:02 PM Thread Starter
jlegan
the single rpm adjusment screw is screwed all the way out and still has a high idle
jlegan is offline
post #4 of 6 Old 08-01-2011, 09:52 PM
MJMPC
Look for a vaccumn leak.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 6 Old 09-06-2011, 11:24 AM
GardenGnome5
Do a smoke test on your vaccum system. If it's idling like that all the time you have a big leak somewhere.
GardenGnome5 is offline
post #6 of 6 Old 09-06-2011, 12:23 PM
SFJeep89
Another thing maybe the intake manifold gasket. If problem gets worst, thst would be my best guess
SFJeep89 is offline
Idle Air Control Valve- High Idle Nibbley15 YJ Wrangler Technical Forum 43 10-16-2014 07:04 PM
2004 TJ 4.0 High Idle after Drive, but then normal idle greenjeepsrule TJ Wrangler Technical Forum 6 11-07-2012 12:52 PM
High Idle, High Pitched Whine, Black Soot PolakX TJ Wrangler Technical Forum 6 02-15-2010 08:34 AM
High idle 2k rpm, idle jumping on braking - Moab in jeopardy AndrewMuadDib TJ Wrangler Technical Forum 9 09-06-2009 11:19 AM
Dead battery, no idle, now high idle. HELP! gudoldboy TJ Wrangler Technical Forum 0 06-29-2008 03:31 PM
