High Flow Cat - JeepForum.com
post #1 of 14 Old 09-18-2001, 07:56 AM Thread Starter
JeeperJay
High Flow Cat
I've got a 92 YJ 2.5 and its time for a new cat. I'm looking for a high flow cat and I was wondering who makes them for this application and where I can find one. Thanks.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #2 of 14 Old 09-18-2001, 06:26 PM
osburn
osburn's Avatar
If you haven't upgraded the rest of your exhaust system, a high flow cat is just gonna be a waste of money. Hell, it's pretty much a waste of money in any case.
Matt Osburn
Score 1032
osburn is offline
post #3 of 14 Old 09-18-2001, 06:57 PM Thread Starter
JeeperJay
I kinda thought I might get an answer like that. I did find some today and they sure aren't cheap. I wish I could just rip the darn thing off but from what I hear its not a good idea with the 4-banger. I think I'll just get a stock replacement. Thanks.
post #4 of 14 Old 09-19-2001, 09:23 PM
91 sahara
summit racing catco hi-flo cat 2 1/4 $59.99
91 sahara 4.0 5sp hardtop 31's on 15x8 m/t classic 2's rock-it air intake and k&n so far.
91 sahara is offline
post #5 of 14 Old 09-20-2001, 09:07 AM
blackjeep
you could always do it this way . Take a piece of pipe not sure what size and just smaah it right though the catand bolt it back up. you will have better exhaust flow and it will still pass inspection
95 wrangler 1.5" springover Dana44 front Ford8.8 rear 4.10's 35x12.50 MTR's
blackjeep is offline
post #6 of 14 Old 09-20-2001, 09:58 PM
I-4
I-4's Avatar
jeeper jay,i have a hi-flo cat with a flo-master.yes on a 4 popper.it is a bit loud,but the muffler helps to change the tone so it doesn't sound as bad as a pimped out rice rocket.as for the other advice given,i think he gets off on pissing in eveybodies cheerios.just my passing thought.
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
post #7 of 14 Old 09-20-2001, 10:33 PM
osburn
osburn's Avatar
Sorry I-4, I just sorta figured he wanted to know the truth.
Matt Osburn
Score 1032
osburn is offline
post #8 of 14 Old 09-20-2001, 10:45 PM
I-4
I-4's Avatar
the whole cat thing won't work without a good muffler.you will have to be careful that you don't lose too much backpressure or it will run like crap.the cat by itself won't do a thing for you.there are several mods that should go hand in hand with this.when these are all put together you get a little something more out of your four popper.remember, it's just a 4 popper,you can only get so much from it.i think this is what "others" where trying to say in their normal pissy fashion.
95 yj...
I-4 is offline
post #9 of 14 Old 09-20-2001, 11:01 PM
osburn
osburn's Avatar
Actually, no that's not what I'm saying. I'm saying 4 banger, 6 whatever, a hi-flow cat ain't gonna make much difference. Although, if sahara has found them for $59, I'd say jump on them. That's a good price for any cat.
Attempting to insult me doesn't make a cat work better by the way.
Matt Osburn
Score 1032
osburn is offline
post #10 of 14 Old 09-20-2001, 11:13 PM
I-4
I-4's Avatar
well here we go,
the engine should ideally be able to breathe better(modified intake)to take advantage of the hi flo cat.there are sveral ways to do that.a modified intake,tb spacer,filter,location of the intake,even a different tb,etc...then on the back side you can do an exhaust manifold as osburn suggested.these things put together with a hi-flo cat and good muffler will give you some more power.one simple trick that will give you the most hp gain is a set of electric fans.i know this gets a bit expensive to do all at once.just do it in pieces as you can,that is the pleasure of building a jeep!
that cat works even better with knowledge!
95 yj...
I-4 is offline
post #11 of 14 Old 09-21-2001, 09:04 AM Thread Starter
JeeperJay
So lets say I don't have any intake or exhaust mods yet. Would a high flow cat actually hurt my performance?
post #12 of 14 Old 09-21-2001, 11:02 AM
Pantera
Considering the age of your rig, my guess is your cat is gonna be pretty clogged right now... Not enough to keep you from running, but prolly stealing power nonetheless... Even putting a stock cat on it will prolly increase your power, but IMHO don't replace, UPGRADE!!! I don't think anyone can argue with that...
Eddie H.
91 YJ 4-Banger
Omaha, NE
Pantera is offline
post #13 of 14 Old 09-21-2001, 01:35 PM
I-4
I-4's Avatar
certainly wouldn't hurt any thing.in my case it was cheaper to go to the flomastr and hi flo cat.everywhere wanted $400 to put it stock.one guy here in irving wanted $250 to put a hi-flo cat and flo master.so the choice was obvious.
95 yj...
I-4 is offline
post #14 of 14 Old 09-24-2001, 03:02 PM
Chris C
Adding a high flow cat could never hurt your performance. However, punching out the existing cat could reduce the back flow too much. If you replace your cat with a higher flow model now, you are most likely to notice the difference once you unrestrict your intake and the rest of your exaust. When I used to drag turbo cars, we explained it like this:
"Take a Burger king straw, and try to take ten deep breaths through it. Now do the same thing without the straw like you normally would. It is the same before and after for your car/truck/Jeep."
-My2Cents
Chris C.
Chris C.
'89 YJ 4 Banger
1 1/2" Shackle Lift
30x9.5x15's on American Racing Nitro 15x8's
Custom Lock Box
Homemade Exaust
More stuff soon.
"I like it dirty"
Chris C is offline
High Flow CAT= Better MPG? TJRanger TJ Wrangler Technical Forum 16 11-06-2007 03:56 PM
High flow cat? snakester14 TJ Wrangler Technical Forum 2 09-30-2007 10:38 PM
Did high flow cat help your 4.0? conor.davis TJ Wrangler Technical Forum 1 01-16-2007 01:54 PM
high flow Cat 05darkness TJ Wrangler Technical Forum 8 05-23-2006 09:57 AM
high flow cat DannyMK2 TJ Wrangler Technical Forum 4 01-26-2006 10:55 PM
