hidden engine disable switch - JeepForum.com
post #1 of 14 Old 02-03-2011, 10:23 PM Thread Starter
Fin_Reaper
On my 96 Dodge Ram 1500 5.2 manual (obd-II), what circuit do you guys recommend installing a hidden engine disable switch? ASD seems like it's too obvious, but then again maybe not.
88 YJ with stuff
Fin_Reaper is offline
post #2 of 14 Old 02-03-2011, 10:39 PM
burnout189
well, thats really not yj tech.................
but, i guess if i insisted on doing so, i would probably go for an ignition circuit. cut the spark. a little less obvious than asd or fuel pump. could put it right in line with the coil i guess. thats up there on the right front of the motor, easy to get to, yet not real noticable.
BARNHART'S AUTO REPAIR
burnout189 is offline
post #3 of 14 Old 02-03-2011, 11:26 PM Thread Starter
Fin_Reaper
Thanks - the 5.2 will be going into my YJ, if that helps, but hardly any of the original YJ harness will be used.
A coil wire seems rather simple - the harness is wide open right now, so it would be easy splice into.
88 YJ with stuff
post #4 of 14 Old 02-03-2011, 11:31 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
On my old XJ I put in a fuel pump kill switch on the main harness. It lets the jeep fire up for a second then die, and doesn't flood your engine with fuel like removing spark would. It worked perfectly.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 14 Old 02-03-2011, 11:45 PM
IPOOD
You can also get a lockable battery lock out goes right in line on your battery cable requires a barrel key like on a soda machine to switch it.
RED JEEP CLUB #619
Originally Posted by jsawduste View Post
I do not claim to know everything. Have been beat up, been proven wrong and hard folks piss in my Cheerio`s.
IPOOD is offline
post #6 of 14 Old 02-04-2011, 08:13 AM
Que89YJ
Easiest is to take a critical sensor to ground.The easiest is the crank sensor. On the signal line of the sensor you chose, somewhere in the harness tap in a wire. Run it to a switch and the other side to ground. Your not switching power so there is no fuse to blow. If you are really into hiding your job grab a normally open magnetic switch. You can use a common refrigerator magnetic to keep it active when you are driving it. Remove the magnetic from what ever spot youve hidded the switch and nobody will ever be able to figure it out.
Que89YJ is online now
post #7 of 14 Old 02-04-2011, 08:31 AM
timatoe
timatoe's Avatar
When I bought the YJ it had one that simply disconnected the 12v going to the starter relay, worked fine. I think the easiest would be to cut power to the fuel pump that way even if it starts initially it'll die and not start again.
timatoe is offline
post #8 of 14 Old 02-04-2011, 09:20 AM
swatgig17
1987 YJ Wrangler
My wife had a Lumina with a 'secret switch'. You had to activate the right turn signal or it wouldn't start.
Mine is more complicated:
Press the gas pedal to the floor, and pull the choke half way out. Release the gas pedal, and press it two more times.
Unless this procedure is followed exactly, the Jeep won't start.
swatgig17 is offline
post #9 of 14 Old 02-04-2011, 09:34 AM
Colockum
How did you do that?
2004 TJ
Not locked or loaded... yet
Colockum is offline
post #10 of 14 Old 02-04-2011, 11:46 AM
timatoe
timatoe's Avatar
It's a carbed 4.2
timatoe is offline
post #11 of 14 Old 02-04-2011, 06:22 PM Thread Starter
Fin_Reaper
Originally Posted by timatoe View Post
It's a carbed 4.2
88 YJ with stuff
post #12 of 14 Old 02-04-2011, 09:57 PM
dodger889
Why not just switch the the ECM power somewhere no one would look. Then nothing will work starter or fuel pump. Then if they try to bypass the ignition switch it still will not work punch the key same thing. Hide the switch in plain sight to look like it should be there or a serial of them to use a combo of which one needs to on or off.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #13 of 14 Old 02-05-2011, 10:25 AM
dennis294
1987 YJ Wrangler
It's a carbed 4.2
3 pumps for mine. And you can't touch the brakes, so if you're on a hill you better be quick about it.
dennis294 is offline
post #14 of 14 Old 02-05-2011, 11:10 AM
drbandkgb
My kill switch runs to the starter..
www.xterranation.org
drbandkgb is offline
Looking for old thread / writeup (Disable AC with new switch) Panici TJ Wrangler Technical Forum 1 05-01-2008 03:50 AM
Airbag disable switch JasonJW TJ Wrangler Technical Forum 2 01-10-2008 09:26 PM
I found a hidden switch skoke70 TJ Wrangler Technical Forum 54 07-27-2006 08:34 PM
disable clutch switch?? coorsmgood TJ Wrangler Technical Forum 8 10-04-2005 07:07 PM
Airbag Disable Switch? K9JEEP TJ Wrangler Technical Forum 10 08-31-2002 01:47 PM
