Quantcast Hid projectors custom for jeep - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Hid projectors custom for jeep
Old 08-24-2009, 09:02 PM   #1
yjbleu
I saw a couple of people want a tread on my projectors i've made for my yj, this tread explain how I did it.
sorry my english is not perfect but i do my best, I'm form montreal, quebec so i'm french
First, i have bought a kit to convert sealed beam to H4 on ebay. This kit include projectors. I already have hid on my jeep but i don't have projectors and I was tired to blind people, it was not too bad but it wasn't perfect. When I received my kit, i put my hid in it and I wasn't very satisfied. A friend gave me 2 hid kit with projectors 3 years ago. One kit come from an audi TT and the other kit I don't know where does it come from. So i decided to put real projectors in the ebay housing because ebay projector are not so good.
this is what i've bought
this is the projector, i will try to find witch car it come from
First, I've cut behind the headlight to be able to put the projector in it. I've started with a saw for metal and then i've made the finish with the dremel to have a circle the more perfect possible
the i just hat to put the projector in place and I've sealed it with rigid epoxy. I had to cut the support of the headlight because i need a bigger hole
this is after
thie is before the epoxy
the ballasts are screwed inside the fender
this is the result
But we always want more and remember that i have a second kit who hung out in my garage so i decided to make auxiliary light with it
these are the projectors that comes from an audi TT (bosch projectors)
I don't have pictures yet but i've put them into an abs pipe of 3". It was'n enough beatiful to put it on my bumper but i've put them under my bumper. I have enough place to clear my sway bar, so they aren't visible during the day. I know it's not the best place for the mud and the rocks but i don't go offroad often (and i don't do difficult trails) so i doesn't matter (and it take like 5 min to remove.)
this is the lighting at 30-35 feet from the garage
only headlights
with auxiliary lights (notice that I need few adjustments, it's not completly finished)
YJ 1988 , TJ 2005, YJ 1994 Part out
yjbleu is offline   Reply With Quote
Old 08-24-2009, 09:33 PM   #2
Hurley91
Looks good and thanks for the write up. I am going to do this near christmas time when i get more money. I think it would be sick if you could do this
- 2000 F150 5.4L Lariat 4X4
Hurley91 is offline   Reply With Quote
Old 08-24-2009, 09:42 PM   #3
yjbleu
i can do that, i juste have to change the blue bulbs for red ones, but it's not like real angel eyes
i have those blue lights because the headlights came with them and there is an hole but i don't turn on often I found them rice
Old 08-24-2009, 10:29 PM   #4
Hurley91
Thats sick. What balast did you use? Was it the one that can with the audi? Thanks
Old 08-25-2009, 08:21 AM   #5
yjbleu
i took the hella ballast from the audi, but the blue lights aren't hid, it's just for the look, i have them because there was a hole.
Old 08-25-2009, 08:29 AM   #6
Hurley91
So i got to get the 2 projector housings, 2 ballasts and 2 projectors. Do you have the LED's wired up on its own switch?
Old 08-25-2009, 09:18 AM   #7
yjbleu
the blue lights it's not led, it's ordinairy lights and they come with the projector housing, i've put a switch on the dash
Old 08-25-2009, 11:04 AM   #8
93jeepyj
That looks good. Ill bet the aux lights would look nice mounted in the bumper and it would kind of protect them also.
93jeepyj is offline   Reply With Quote
Old 08-25-2009, 11:52 AM   #9
yjbleu
yes but there is no place in the bumper
Old 08-25-2009, 12:01 PM   #10
93jeepyj
On either side of the frame there is unless the housings are just bigger then the bumper height. Ive planned to do something similar with just some regular aux lights for a while just other more critical stuff keeps coming up.
Old 08-25-2009, 08:06 PM   #11
yjbleu
ya but I have looked and it and it was coming too close of my tire, but it depends of the kind of projectors you use
Old 10-02-2009, 05:11 PM   #12
Onion22
Wow. that looks really nice, I may have to keep an eye out for some cheap projectors. I was going to just get HID bulbs but I may have to try this with my LJ sometime. Great work
-Sry bout my speling, i went too public school... an not dat offten.
- Member of "Kansas Mountain Rescue Patrol" if i see a mountain I'll rescue it.
White Rubi LJ, 6spd, 35" BFG KM2's My LJ Build Attempt
Onion22 is offline   Reply With Quote
Old 10-02-2009, 05:48 PM   #13
southbound
Thanks for the write up. I did an H4 conversion awhile back. The light output from the H4's put off way more light when compared to the OEM configuration and it gave me that nice flat line of light when in low beams (similar to HID). But the light output of this mod looks even better. This may be something that I'll try to tackle later on. Thanks for the inspiration .
I'm assuming that the ballasts, HID bulbs and other critical components could be had at a junk yard? I'm not very familiar with HID setups. What types of vehicles would be a good donor? And what parts should I pull?
Thanks ,
1995 YJ Wrangler Sahara
2004 WJ Grand Cherokee Limited V8
southbound is offline   Reply With Quote
Old 10-17-2009, 10:24 PM   #14
cyoos
Those projectors are awesome. How difficult are they to aim correctly, and what's the target point of aim? Isn't it 4 feet high at a distance of 25 feet or something like that?
cyoos is offline   Reply With Quote
Old 10-24-2009, 10:59 AM   #15
yjbleu
Thanks ,
the ballast and hid bulbs you can go at any place they sale performance parts, you can try on ebay or meaby in a junk yard.
For the projector, you can take almost any projector. For my auxiliary light, i took bosch projectors, like on audi or porsche.
Glock Forum
