hi,guys,a little help,thanks!!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > hi,guys,a little help,thanks!!!!
KOR Name Your Price SaleThe Original 3/8" Ruffstuff Diff Cover!Steering and more from Ruffstuff!
Unread 02-09-2015, 07:21 PM   #1
Follyjeep
i have a problem to remove the dropper pitman arm,i afraid to Brock the tool,the same with the control arm bolt ,send pics,thanks
Follyjeep is offline   Reply With Quote Quick reply to this message
Unread 02-09-2015, 08:12 PM   #2
JeeperDon
Patience, Grasshopper
JeeperDon's Avatar
Get tension on the pitman tool, then use a BFH on the arm end. If you are worried about the tool popping off you might add a c-clamp to keep it from spreading off. As a last resort (assuming you can think of more resorts than my BFH and clamp ideas), cut it off with an angle grinder and get a new pitman.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" BFG KM2's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
Unread 02-10-2015, 12:59 PM   #3
Que89YJ
http://www.jeepforum.com/forum/f12/h...an-arm-859079/
cut it.
Que89YJ is online now   Reply With Quote Quick reply to this message
Unread 02-10-2015, 01:07 PM   #4
bob8619
When I removed mine I thought something was about to break but I kept going and it eventually popped loose.
bob8619 is offline   Reply With Quote Quick reply to this message
Unread 02-10-2015, 01:39 PM   #5
bill8bud
Originally Posted by Que89YJ View Post
I spent two days fighting mine. I used heat, BFH, broke two AZ pullers, soaked it for weeks before I was gonna pull it. Just cut the thing off and use an air chisel to spread it.
Just to make sure cut it with a cut off wheel parallel to the shaft.
bill8bud is online now   Reply With Quote Quick reply to this message
Unread 02-10-2015, 05:57 PM   #6
maddoc
after messing with mine for a while i gave in and cut it with a angle grinder....i was careful to go just before the splines then one whack with a BFH while under tension and it went flying.
maddoc is offline   Reply With Quote Quick reply to this message
Unread 02-11-2015, 06:35 AM   #7
Follyjeep
Thanks,guys ,let see today if not going with the pooler, i will cut but the way ,what is "bfh"?
Unread 02-11-2015, 07:02 AM   #8
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Your best friend on a Jeep, a 2.5 pound one is nice, but I even have a 5 pounder. Big Freaking Hammer = BFH
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
Unread 02-11-2015, 06:19 PM   #9
Follyjeep
i solve the problem,thanks guys!!!!
