Quantcast hey v-8 idaho - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > hey v-8 idaho
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 05-10-2002, 10:39 PM   #1
Jeepfreak81
hey v-8 idaho
hey when you did your v-8 swap did you have to change your drive shafts??? im planning on using my stock t-case bcuz i dont offroad HEAVILY bcuz its a daily driver, but alot of people are saying i will have to change them, i was also planning on 2" lift helper springs or overlaods whatever you call them, and if i did that with a shackle lift would they need lengthened -- the shafts, i just know you have the 8 and i saw what a 3" lift on your profile?? i am not sure hope you can answer these...
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies TRAIL TESTED (currently under the knife)
1946 CJ2A, 225 V6. mild lift - TIME TESTED
1966 M416 1/4 ton Military Trailer -- WAR TESTED
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline   Reply With Quote
Old 05-11-2002, 06:24 PM   #2
V8wrangler_idaho
well the drive lines all depend on if putting the v8 in changes the position of your tranny and case. if it will move it forward or back a little. thats all that it would matter if you need new drive lines or not. the drive lines that are on the jeep right now sould be able to handle the power just fine. it would only depend on if the t case was still in the exact same place as it was befor the swap to the v8
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline   Reply With Quote
Old 05-11-2002, 10:45 PM   #3
Jeepfreak81
so in other words i need to obtain my engine and tranny and measure them fromt he motormounts back... or at least where the old ones were back and compare to the new engine and i wont know till then or did i just confuse you as much as myself!
Old 05-12-2002, 09:49 PM   #4
V8wrangler_idaho
ya thats right. If you have the same measurment from moter mount to tranny mount from both the stock motor and new motor. or if the new motor is just slitly longer since your lifing your jeep then you sould be fine.
Daniel Mclay
Glock Forum
