Hey, I'm new here.. Help with gears - JeepForum.com
post #1 of 4 Old 09-20-2001, 02:51 AM Thread Starter
bighair
Hey peoples,
I have a 93 yj 4.0. I'm looking at swaping gears.. I still have stock gears on her (3:73's). I wasn't sure what gear ratio is better. lower or higher?? IE: are 3:73's better then 4:11's?? etc..
Any suggestions on what I should be getting?
Thanks in advance for your help..
BigHair
Team Mod Squad
We are here to help YOU!
bighair is offline
post #2 of 4 Old 09-20-2001, 03:07 AM Thread Starter
bighair
Hey there,
Right now I have Bfgoodrich MT's 235's and I'm looking into getting 33" tires. This is why I want to swap gears.
Thanks
Team Mod Squad
bighair is offline
post #3 of 4 Old 09-20-2001, 06:04 AM
Cinderella
Hi there,
If you want to get the same handling characteristics as you have right now with your smaller tires you should go for 4.27 with those 33"s. If you are serious about off-road-performance: 4.56
You can check it out for yourself at http://www.4lo.com (click on "Gear/tire size table" in the Calculator-banner)
enjoy
JOS
92YJ (2,5L 4cyl, K&N-Cyclone-restrictor.removed..., HP-exhaust,HD clutch, 2,5"SL,1"BL, Rancho, SYE, Revolver, Quick Disconnects, telescopic track-bar, 33*9.5*15MT)WARN9000
Cinderella is offline
post #4 of 4 Old 09-20-2001, 11:39 PM Thread Starter
bighair
Thanks Jos, I looked at the site And saved it in my favorites places.. it'll come in handy..
You ROCK!!! hehe
Team Mod Squad
bighair is offline
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 08:19 PM
Jk Rubicon 4:10 gears vs. 1974 Chevy 4:10 gears (pics) Xtremjeepn JK Wrangler Technical Forum 15 12-03-2009 09:09 PM
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 06:34 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 09:55 AM
Will a differnece be noticed from 3.07 gears and 33" tires to 3.73 gears chaznad TJ Wrangler Technical Forum 9 08-26-2005 10:54 AM
