#1 | |
hesitation off idle 89 2.5L
I'm having a really strange problem, when I'm at a stop and give it gas it will sputter like its out of gas then after a few seconds of adjusting gas/clutch it will drive just fine. It doesnt sputter if I rev the engine with the clutch in or in Neutral. Only when I try to move from a stop. Upper RPMS are just fine. Help.......
I wish the search engine was up ![]()
1989 Red YJ 2.5L 5speed(stocker) 2001 Silver WJ Larado 4.7 V8, Quadra Drive 1990 Red XJ Limited *sold* |
#2 |
Oh I forgot to mention, that the magic number seems to be up to 2k rpms. After that she will run up to redline without a hiccup.
#3 |
BUILT. NOT BOUGHT.
tried replacing the fuel filter yet?
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#4 |
great idea get this stuff called sea foam u can get it at auto zone u may have clogged injectors or something.. i had the same prob. well the 2.5 is fuel injected.. but get that stuff if u can its 6 bucks and it will clean alot of the carbon depostits out of ur engine and u will get better milage and it will stop that hesitation
#5 |
Fuel filter is new as well as,wires, and plugs, I will pick up some of that sea foam today and see how it goes.
#6 |
picked up sea foam havent had a chance to use it yet, I noticed something though. Now that the weather is getting warmer, the problem went away. It seems it only does it when the weather is cold, regardless if the engine is up to temp or not. ????
#7 |
Is your choke fully disengaging?
Fuel filter? |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
