Hesitation in higher gears - JeepForum.com
post #1 of 2 Old 08-08-2011, 09:19 AM Thread Starter
Fouse8806
is anyone else getting hesitation in 4th and 5th gears? i have to put the petal to the metal just to get my jeep up to 70....any ideas on why? ive changed the plugs and wires and am replacing the fuel filter and am going to put some injecter cleaner through it....think it will help?
Fouse8806 is offline
post #2 of 2 Old 08-08-2011, 09:53 AM
Buddha
Fill out your Jeep profile so we know what you are driving and can help you. Also, explain what it's doing in a little more detail because what you have described so far could be caused by a lot of things. Was it doing it before you changed the plugs and wires? If not, what brand/type of plugs did you install? Did you check the gap on them?
All the stuff you've done and are planning to do will help it run better. Just don't know enough about your problem to know if it will correct the issue.
I have read hundreds, if not thousands, of threads on here and it's amazing the percentage of problems that wind up being caused by something the owner has accidentally done to the Jeep while working on it.
Moral to the story: If you moved it, unscrewed it, unbolted it, hammered on it, wiped it off, re-wired or replaced it - Check there first!
Buddha is offline
4.0 runs like a go-cart in higher gears! Yellowhammer TJ Wrangler Technical Forum 12 06-16-2010 07:05 AM
Faint high-pitched rattling noise in higher gears... Spank JK Wrangler Technical Forum 7 04-22-2010 08:43 AM
Cutout in higher gears help? PittBoy YJ Wrangler Technical Forum 6 08-27-2009 03:00 PM
how much higher TJ's Tj TJ Wrangler Technical Forum 4 06-27-2007 04:00 PM
Want the LJ to look higher.. obert272 TJ Wrangler Technical Forum 13 02-08-2007 07:20 PM
