Quantcast Herculiner vs Duplicolor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Herculiner vs Duplicolor
Old 12-01-2007, 01:09 AM   #1
Jeebs
I am looking to do my tub pretty soon and am just curious as to what home done liner has worked the best for people. I've heard good things about Herculiner and relatively little about Duplicolor. The Herculiner is about $90 locally and the Duplicolor is $45. I am assuming there has to be a reason for the extreme price difference.
Thanks in advance for the input
San Diego Group
Jeebs is offline   Reply With Quote
Old 12-01-2007, 01:28 AM   #2
texastorso
1978 CJ7
I would say herculiner all the way. I reseached for af ew weeks and found nothing but good rmarks about it. I rolled it on my 93 YJ about a month ago and it is great.
I just removed everything from the jeep and preped the metal roughed it up with 120 sandpaper and then washed it out. Then wiped it down with acetone. Wiped it down again with dry rag and then taped off the jeep. I did not care for perfection some I did little taping. I put on 2 coats everywhere and 3 where the most traffic would be in the jeep. I let it sit over night then put everything back in the jeep.
It turned out great, Yea some corners dont look perfect but I dont care and I saved 500 bucks.
Here are some pics.
Astros 4 Life
texastorso is offline   Reply With Quote
Old 12-01-2007, 01:32 AM   #3
JeepMan1975
Click free!
Originally Posted by texastorso
Here are some pics.
Sitting in your Jeep does NOT count as a mod!
JeepMan1975 is offline   Reply With Quote
Old 12-01-2007, 03:38 AM   #4
jeepjared84
Do the herc. I did Duplicolor in mine and my buddy did Herc. His is 10x better. It has great texture to it, where as the duplicolor doesn't have much at all. It has also started to flake off in a few spots. Yes, it is more money, but in the long run it is money well spent. I am going to end up redoing mine in Herc.
1995 YJ 4.0L automatic
SOA on 1.5" Superlifts
35" BFG A/T's on AR 767's
D30/8.8 4.56 gearing
jeepjared84 is offline   Reply With Quote
Old 12-01-2007, 08:04 AM   #5
Shenandoah
I was out of funds and originally used duplicolor. Then last summer, I applied the Herc over the duplicolor.
Herc is much, much better.
Turn a wrench, save a tree
Shenandoah is offline   Reply With Quote
Old 12-01-2007, 08:52 AM   #6
xxxflhrci
Herculiner...........You can get a gallon at Walmart for 78 bucks.
xxxflhrci is offline   Reply With Quote
Old 12-01-2007, 09:20 AM   #7
obsessedjeeper
herc is wonderful
Keep on Jeepin
95 YJ
98 ZJ
obsessedjeeper is offline   Reply With Quote
Old 12-01-2007, 12:23 PM   #8
Polo
Herc is gods gift to bare metal
Polo is offline   Reply With Quote
Old 12-01-2007, 12:31 PM   #9
jeepinMatt
do herc and spray it on. it looks almost the same as line-x. rolling it on looks good to, thats what i did but i have seen it sprayed on and wish i had sprayed mine on.
jeepinMatt is offline   Reply With Quote
Glock Forum
