Herculiner How To, with questions and answers!! - Page 7 - JeepForum.com
post #91 of 223 Old 09-14-2008, 06:46 PM
ufatbastehd
I've always wanted to herc my wheel wells just haven't had the time.
ufatbastehd is offline
post #92 of 223 Old 09-14-2008, 09:05 PM
94YJJoe
Yeah im thinking that the tub and the wells will be the way to go
94YJJoe is offline
post #93 of 223 Old 09-14-2008, 09:38 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Look up the Herculiner How to string in the FAQ, and search "DIY Herculiner" string. You will have enough to do all the tub X2, with enough to do a 3rd coat on the high wear surfaces. I even pulled out my heater box and went up behind it on the firewall and had about 3 oz leftover. Very worthwhile thing to do to your tub.
You will also be able to read that your outcome will depend on the prep work you do. "It's all in the prep."
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #94 of 223 Old 09-14-2008, 09:53 PM
94YJJoe
thank ya much opihi
94YJJoe is offline
post #95 of 223 Old 09-14-2008, 09:59 PM
Semi-stockYJ
Originally Posted by 94YJJoe View Post
thank ya much opihi
I should be getting some for free soon, and I can't decided where I want to put it
Semi-stockYJ is offline
post #96 of 223 Old 09-14-2008, 10:17 PM
94YJJoe
How much are you getting for free?
94YJJoe is offline
post #97 of 223 Old 09-15-2008, 06:46 AM
derfballs
Just an FYI, the amount everyone above has recommended is if you are rolling. If you are spraying, prepare to use about twice as much. I figured on the gallon when I bought the stuff but once I started spraying, I realized that there is alot of waste and soon found myself running out for more. Comes out amazing but definitely costs you more money due to the overspray. Difficult to control with the cheap gun you are forced to use for this process.
derfballs is offline
post #98 of 223 Old 09-15-2008, 06:52 AM
jeepwrnglr92
2015 JK Wrangler
1 gal and i did like 3 coats...
I used the cheapo wall mart brand on my TJ and I can see it is not nearly as thick. I dont use that Jeep for much so it should be fine. I may strip it and redo it later or go over it with Herc.
Definitely get the Herc, not the off brands
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline
post #99 of 223 Old 09-15-2008, 01:59 PM
brianOU
i sprayed durabak with a 15 dollar gun from eastwood. got 2 good coats and had some left over so i sprayed it heavy in the floorboards. this guy has got a very good writeup.
http://www.bustedjeep.com/projects/herc.asp
here is some pics of how mine turned out:
http://www.jeepforum.com/forum/f176/uv-durabak-pics-574994/
brianOU is offline
post #100 of 223 Old 09-15-2008, 04:50 PM
rocknjeep
1987 YJ Wrangler
I just did mine. I'll throw some pics up but it came out looking great! 1 gallon is plenty. I will say though that the roller they give you didn't do it for me. Me and my buddy used big brushes for the whole deal.
rocknjeep is offline
post #101 of 223 Old 09-15-2008, 09:24 PM
derfballs
Just remembered that I also did the outer firewall, fenderwells, and tub underside... no wonder I used so much. 1 gallon probably would have done me just fine for interior only.
post #102 of 223 Old 09-16-2008, 01:22 AM
rocknjeep
1987 YJ Wrangler
Well I did the firewall, and everything too still had a bit left over and we laid it on thick.
post #103 of 223 Old 09-16-2008, 06:37 PM
YJake
I plan on doing it this weekend and have already started to prep.
A few bolts on the roll cage are frozen so taking it off is not an option. Hell, I might just herc the roll cage too!
I too have the plastic crap lining the wheel wells and it is rotting away quickly. I may buy an extra quart and use it to do a few coats down there as well as my bumpers
YJake is offline
post #104 of 223 Old 09-19-2008, 07:36 PM
YJake
I put in my Herculiner today and it looks great!
Thanks to the info in this write-up
Can't wait to drive around without a roof now and not give rain a second thought!
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #105 of 223 Old 09-19-2008, 07:42 PM
DiabloYJ
I just started this project today and didnt get much done. Well, I did get all of the seats taken out as well as the carpet so I guess its something but when it came time to take out the roll bar I stripped at least 4 bolts so far and just gave up for the night. Looks like Ill be putting the herculiner down with the roll bar still in now
DiabloYJ is offline
lift questions , ive searched but no definite answers XlostJeepX TJ Wrangler Technical Forum 5 09-01-2009 06:45 AM
350 conversion questions (hopefully answers) demoguru YJ Wrangler Technical Forum 1 11-25-2008 10:07 AM
3 questions with easy answers !?! jeep2008 TJ Wrangler Technical Forum 19 10-07-2008 05:39 AM
Frequently Asked Questions (FAQ) Your Answers Are Usually Here! NaeKid YJ Wrangler Technical Forum 16 12-16-2007 11:10 PM
Three quick questions I couldnt find answers to redline73 JK Wrangler Technical Forum 12 12-07-2007 12:58 PM
