Herculiner How To, with questions and answers!! - Page 6 - JeepForum.com
post #76 of 223 Old 08-23-2008, 12:42 PM
Opihi59
from here it gets rough
Opihi59's Avatar
UltimateCC---Yes, you got a ****ty can, no doubt. I wouldn't give up on Herculiner yet. You must have got old old stock from somewhere. Hopefully you can take it back to them. I had to special order mine ($$$) since I wanted gray, it was plenty soupy, but required stirring to resuspend the particles from the bottom.
It's worth it.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #77 of 223 Old 08-23-2008, 02:01 PM
UltimateCC
I am down in St Kitts for school with the jeep so i won't be able to return it, i just ordered another can but i gotta wait a week or two for it to arrive here...so jeep will be chilling for a while...
UltimateCC is offline
post #78 of 223 Old 08-23-2008, 10:22 PM
J-Quad
UltimateCC,
Here's a thought for your consideration:
Maybe it would be worth your while to locate a paint or hardware store that has a paint can 'shaker' and ask them to put your can of Herculiner on the shaker. The shakers normally have a timer on them so see if you can have them set it for at least 5 minutes. I've taken partial/old paint cans back in to my local guy and he's shaken them for me. If your local guy isn't real willing, offer to pay him a buck or so to shake up your can...
Good Luck! J-Quad
J-Quad is offline
post #79 of 223 Old 08-23-2008, 10:25 PM
UltimateCC
I actually thought of that today, I ordered another can, should have it in a week or so and will bring it to the local store and have them shake it up, also ordered 4 cans of plasti kote canned bed liner as a back up because I really need to get the jeep up and running soon...
appreciate the advice, this is why I love forums...you can learn almost everything you need on here...
post #80 of 223 Old 08-24-2008, 07:46 AM
Mazookie
2003 WJ
I can't wait to do this, I have the bug so bad.
~Mazooks~
03 WJ Limited, 4.7L, Quadra-drive, Firestone Destination A/T (245/65/17), Run Valvoline Max Life 10W-30, More to come
"Dont tread on me is what it says and I'll take that to my grave..."
~RIP 87 YJ~
Mazookie is offline
post #81 of 223 Old 08-28-2008, 05:29 PM
UltimateCC
got my new can, much better this time around, i must of had a bad can, i should have most of the jeep together tomorrow...
post #82 of 223 Old 08-28-2008, 10:54 PM Thread Starter
Jeebs
2015 JK Wrangler
Call Herculiner and tell them about the bad can. They will send you another. I had a can burst on me and I called them and they sent a new one free of charge. I had already bought a replacement but just returned the one they sent to Kragen.
Jeebs is offline
post #83 of 223 Old 09-10-2008, 01:48 PM
FIREMAC77
1980 CJ7
Fantastic Advice!! Thanks For The Tips {i Hope When I Get Around To Doing Mine That It Turns Out So Well.}
FIREMAC77 is offline
post #84 of 223 Old 09-12-2008, 01:20 PM
Travs92Cherokee
1992 XJ Cherokee
Hey, looks awsome, I like hurculined some stuff on my Jeep and it is prety durable, I covered my custome made bumpers and bottom stip on the doors and rockers
Travs92Cherokee is offline
post #85 of 223 Old 09-14-2008, 05:54 PM
94YJJoe
Herculiner MOVED TO THE HERCULINER THREAD IN FAQ
Does anyone know how much herculiner it takes to do the tub of the yj. 1 gallon or more less etc.
94YJJoe is offline
post #86 of 223 Old 09-14-2008, 05:54 PM
ufatbastehd
IIRC I used a gallon on mine. I laid down a few coats
ufatbastehd is offline
post #87 of 223 Old 09-14-2008, 06:01 PM
fyrdriver
1983 CJ7
1 gallon is plenty. I did 2 coats like the instructions say and had about a half inch left. Thought I would save it for touch ups. It dried in a couple days.
fyrdriver is offline
post #88 of 223 Old 09-14-2008, 06:02 PM
Brandon_YJ
1987 YJ Wrangler
1 gallon of *any* liner will do the trick. But more never hurt anyone.
I used less than a gallon of urathane to line my tub and am happy with the results.
All the writeups I've seen on here, they have only used one gallon as well.
But definately lay an extra coat or two on the traffic areas (front-drivers floor board and bed of tub).
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #89 of 223 Old 09-14-2008, 06:02 PM
Lumpymayo
1 gallon worked here. 2 coats. Had some left over not enough for a 3rd coat so I poured it on the floor pans and in the back where my tools go.
Lumpymayo is offline
post #90 of 223 Old 09-14-2008, 06:06 PM
94YJJoe
Thanks everybody. Do you guys think that the rear fender wells out to be coated. all the plastic crap that used to be there has cracked and is all but gone
94YJJoe is offline
lift questions , ive searched but no definite answers XlostJeepX TJ Wrangler Technical Forum 5 09-01-2009 06:45 AM
350 conversion questions (hopefully answers) demoguru YJ Wrangler Technical Forum 1 11-25-2008 10:07 AM
3 questions with easy answers !?! jeep2008 TJ Wrangler Technical Forum 19 10-07-2008 05:39 AM
Frequently Asked Questions (FAQ) Your Answers Are Usually Here! NaeKid YJ Wrangler Technical Forum 16 12-16-2007 11:10 PM
Three quick questions I couldnt find answers to redline73 JK Wrangler Technical Forum 12 12-07-2007 12:58 PM
