Herculiner How To, with questions and answers!! - Page 4 - JeepForum.com
post #46 of 223 Old 07-02-2008, 10:53 PM
apexjeepinjoe
think about line X
~Joe~
2012 Wrangler Rubicon(my woman's ride)
2002 Wrangler Apex Edition(with lots of goodies)
1988 Comanche(stock for now)
1970 Jeepster Commando(a work In progress)
apexjeepinjoe is offline
post #47 of 223 Old 07-02-2008, 11:01 PM
dustin87
i did that yeserday it turned out realy nice shame i wasent part of this fourm at the time had to figuer it out my self not to hard tho hard ist part was the prep work all so most inportint part
dustin87 is offline
post #48 of 223 Old 07-02-2008, 11:14 PM
havasu
On permanent vacation
havasu's Avatar
^ (I'm so glad I'm not an English teacher right now!)
havasu is offline
post #49 of 223 Old 07-02-2008, 11:33 PM Thread Starter
Jeebs
2015 JK Wrangler
Originally Posted by hansonian View Post
is it possible to paint over the herculiner? the reason i ask is because i've seen people say it fades and i was planning on doing this to my jeep. although since the interior of mine is gray maybe if i do it black and it fades it won't look so bad.
Check the Herculiner website. They make a product that is meant to go over the Herculiner as a sort of top coat. It has stuff in it to prevent UV damage.
Originally Posted by kingkong33 View Post
Could I just sand the tub down or do I need to scrub it with acetone?
As said before, the amount of prep you put into it will dictate the outcome.
Originally Posted by anarchyfor2 View Post
newblue, just completed this and i followed the instructions you posted, turned out awesome, thanks for doing this, made me alot more comfortable with doing this and savedme quite a bit of cash. your ever in my area, ill buy you some beers.
Good deal! Now I have an excuse to head out to Panama City again!
Originally Posted by apexjeepinjoe View Post
think about line X
Line X is a great product no doubt. The difference is that Line X can easily run over $400 while Herculiner is usually under $100. It takes more elbow grease but to some its worth the savings.
Jeebs is offline
post #50 of 223 Old 07-03-2008, 01:56 PM
jeepbro's
did you dip your brush and roller straight into the gallon or did you use a pan?
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
post #51 of 223 Old 07-03-2008, 07:49 PM Thread Starter
Jeebs
2015 JK Wrangler
I used a pan for the roller and dipped the brush straight into the gallon bucket. Use a disposable pan because you will never get it out.
Make sure you are constantly stirring it too!
Jeebs is offline
post #52 of 223 Old 07-03-2008, 08:02 PM
UltimateCC
I just ordered a can for mine...can't wait...
UltimateCC is offline
post #53 of 223 Old 07-08-2008, 07:11 AM
hansonian
thanks for the info i will ordering the stuff to do mine next week.
hansonian is offline
post #54 of 223 Old 07-09-2008, 11:39 AM
greyser
question. I will be doint mine this weekend.
Previous owner had rubber matting in. In the back they have drilled 8 holes...these were used to screw the front and back floor piece together...
If I just apply the herc over it should it be okay? I was thinking that I should maybe spray por15 so it runs in to the holes...
any ideas?
greyser is offline
post #55 of 223 Old 07-09-2008, 08:25 PM Thread Starter
Jeebs
2015 JK Wrangler
I would imagine that as long as there is no rust currently in the screw hole the Herculiner would be fine. Just make sure and dab a bit along the exposed metal edges to cover it up.
Jeebs is offline
post #56 of 223 Old 07-09-2008, 10:05 PM
irish_loveAWD
Green Newbie
irish_loveAWD's Avatar
1993 XJ Cherokee
Translated to English for you:
I did this yesterday, and it turned out really nice. It's a same I wasn't part of this forum at the time, as I had to figure this out by myself. It wasn't very hard though. The hardest part was the prep work, which is also the most important part.
irish_loveAWD is offline
post #57 of 223 Old 07-09-2008, 11:20 PM
havasu
havasu's Avatar
Thanks for deciphering the code for me!
havasu is offline
post #58 of 223 Old 07-10-2008, 07:15 AM
greyser
Cool! thank ya much!
greyser is offline
post #59 of 223 Old 07-13-2008, 09:23 AM
TJSport01
i have been prepping mine for the past few days, slowly getting it ready for herc and i have a question i rough it up with the pad so there is no more shiny left on the tub but then when i wipe it with acetone it basically goes back to what it looked like before i roughed it up does that mean i need to do a better job roughing it up or is that normal
Build Thread:
2001 Jeep TJ, 1in JKS Body Lift, 35x12.50x15in Goodyear Mtr's and a RE 4.5 SF with AA sye, tom woods custom cv drive shaft, tnt tube fenders w/3in flares and flush mounted led turn signals, 1in mml, cobra cb and firestik, custom rock sliders, herced, trail scars
Looking for 4.88s (R&P) for a d44/d30 PM me
TJSport01 is offline
post #60 of 223 Old 07-13-2008, 06:01 PM Thread Starter
Jeebs
2015 JK Wrangler
You want just want a rough surface for the stuff to bond to. It doesn't need to be gouged or anything, just not perfect shiny clean.
Jeebs is offline
lift questions , ive searched but no definite answers XlostJeepX TJ Wrangler Technical Forum 5 09-01-2009 06:45 AM
350 conversion questions (hopefully answers) demoguru YJ Wrangler Technical Forum 1 11-25-2008 10:07 AM
3 questions with easy answers !?! jeep2008 TJ Wrangler Technical Forum 19 10-07-2008 05:39 AM
Frequently Asked Questions (FAQ) Your Answers Are Usually Here! NaeKid YJ Wrangler Technical Forum 16 12-16-2007 11:10 PM
Three quick questions I couldnt find answers to redline73 JK Wrangler Technical Forum 12 12-07-2007 12:58 PM
