Herculiner How To, with questions and answers!! - Page 11 - JeepForum.com
post #151 of 223 Old 04-30-2009, 07:18 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
Originally Posted by il_marcello View Post
Ok, dumb question: what are the benefits of herculining the tub, apart from aesthetics?
(I really like how it looks, btw)
Thanks!
grip on the floor.. no carpet= can leave top off and no mildew..... protects against rust... looks awesome.
Thomas
-1987 YJ
Tompatt is offline
post #152 of 223 Old 05-03-2009, 10:55 AM
MrGhostWalker
How long does it last before needed to be re-done/touched up?
-mrghostwalker
And this be our motto: "In God is our trust"
And the star-spangled banner in triumph shall wave
O'er the land of the free and the home of the brave!
MrGhostWalker is offline
post #153 of 223 Old 05-03-2009, 11:21 AM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
just depends on how much damage you give it.
Thomas
-1987 YJ
Tompatt is offline
post #154 of 223 Old 05-09-2009, 07:35 PM
SteeleMan
I just herculined my tub on my TJ, and after 2 coats, I still have a little more than a 1/4 left of the gallon, was I putting it on to light?, should I give it one more coat?
'98 TJ
SteeleMan is offline
post #155 of 223 Old 05-11-2009, 11:51 AM Thread Starter
Jeebs
Jeebs's Avatar
You can use it all if you'd like and just have a thicker coat. I had quite a bit left and did extra coats in the heavier traffic areas. Floorboards, rear cargo area, etc.
Jeebs is offline
post #156 of 223 Old 05-11-2009, 12:12 PM
CaptainJaxx
You probably put it on too light if you have that much left over. I'd recommend using it all. No reason to waste it.
CaptainJaxx is offline
post #157 of 223 Old 05-12-2009, 09:08 AM
xplodn
Any of you guys that did it in the beginning have any current pictures? Id like to see how it holds up over time... thanks.
xplodn is offline
post #158 of 223 Old 05-12-2009, 09:33 AM
CaptainJaxx
Mine hasn't been on that long, but it dries very hard, so it seems to be pretty durable. It dries rough like sandpaper and will take the skin off your knuckles very easily :-) It's not rubbery like you might expect.
post #159 of 223 Old 05-12-2009, 10:23 AM
DiabloYJ
I can go get some pictures for you in a few minutes...plan on cleaning the Jeep out a bit so Ill snap some pics.
DiabloYJ is offline
post #160 of 223 Old 05-12-2009, 12:19 PM
SteeleMan
Good call, I will put more coats where it will get the most abuse. Thanks
'98 TJ
post #161 of 223 Old 05-19-2009, 11:30 AM
FlyguyTKI
I wanted to herculine my Rock Sliders I am about to build and am wondering what the best way to apply it to round tubing would be?? Any ideas??
-david
Texas Jeep Owners Club Member # 101
2007 Red Rock 2dr X JK
FlyguyTKI is offline
post #162 of 223 Old 06-12-2009, 03:27 PM
dancytron
just put on the second coat
Almost everything has been said, but I will add that buying the cheapest respirator (even with the correct filter) is probably not the way to go.
It seems to work okay when my head is straight up, but whenever I bend over, I get a big whiff of xylene or whatever it is. No headache yet, but a pretty good buzz that is probably not too healthy.
If I ever do anything like this again, I'll spend more than $25 and get a better mask.
Dan
Last edited by dancytron; 06-12-2009 at 03:31 PM. Reason: xylene is bad for spelling and punctuation
dancytron is offline
post #163 of 223 Old 06-12-2009, 09:19 PM
hevybluzer
Most mega-home improvement stores sell rollers that are made just for painting pipes (tubing)
hevybluzer is offline
post #164 of 223 Old 06-22-2009, 12:28 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I am finally getting around to installing my herc this week. I have one question though. With the bare metal, after you prime it, can you put the herc right down on top of the primer or should you clean it and scuff it first?????
rustywrangler is offline
post #165 of 223 Old 06-22-2009, 08:09 PM
Opihi59
from here it gets rough
Opihi59's Avatar
I scuffed the primered spots, Herc'd over that and it is holding up fine after 16 months. The primed spots were in high wear areas, which of course still remain high wear areas and there is no sign of it loosening up any at all.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
lift questions , ive searched but no definite answers XlostJeepX TJ Wrangler Technical Forum 5 09-01-2009 07:45 AM
350 conversion questions (hopefully answers) demoguru YJ Wrangler Technical Forum 1 11-25-2008 11:07 AM
3 questions with easy answers !?! jeep2008 TJ Wrangler Technical Forum 19 10-07-2008 06:39 AM
Frequently Asked Questions (FAQ) Your Answers Are Usually Here! NaeKid YJ Wrangler Technical Forum 16 12-17-2007 12:10 AM
Three quick questions I couldnt find answers to redline73 JK Wrangler Technical Forum 12 12-07-2007 01:58 PM
