Herculiner DIY kit? - JeepForum.com
post #1 of 6 Old 08-18-2004, 01:26 PM Thread Starter
4wheelinfool
4wheelinfool's Avatar
1980 CJ5
Herculiner DIY kit?
i went out to Pep Boys and bought the herculiner DIY kit for 96 bucks. I will start my prep work on it this weekend. Do any of you have the herculiner, and how does it hold up to the heat adn abuse? How easy was it to put in? and how many coats were you able to put on with the one gallon that they give you in the kit?
Thanks for all the help...
4wheelinfool is offline
post #2 of 6 Old 08-18-2004, 02:48 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
did it on mine and i love it. 2 full coats and a third in the high traffic spots. check out the FAQ, i posted some tips in there.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #3 of 6 Old 08-18-2004, 06:19 PM
93YJjeep
I did mine this spring, I ended up using a little over a gallon, still have a bit left for touch up spots (bought a gallon and a quart for about $80). I coated everything atleast 3 times very heavily including the rollbar (enough to go under the padding a couple of inches). I am very happy with it, better than the carpet that as in there. When I did mine I took the whole interior out, including the rollbar. Only tip I have is to spend a bit on cheap bolts and plug the bolt holes so they don't fill up. When you are done you just unscrew them and the threads aren't messed up.
93YJjeep is offline
post #4 of 6 Old 08-18-2004, 06:31 PM
drew2000
drew2000's Avatar
I just finished mine, love it. Used about 1/2 gallon for most of the tub, there were a few areas I didn't want herc'd.
One tip, make sure to do it all in one day so your rollers dont try out like mine did.
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #5 of 6 Old 08-19-2004, 08:33 AM
pennjones
i did mine and love it. 2 full coats with some still left over (probably dried out now). it holds up very well. take your whole interior out, as previously stated. makes everything so much easier. i used a brush and sort of dabbed it on for a thicker look. it's really hard to clean, but it's a jeep, who cares. you should have looked around a little though, i just saw the other day that it was on sale at autozone for $79.
pennjones is offline
post #6 of 6 Old 08-19-2004, 02:48 PM
sentinal02
sentinal02's Avatar
hell of a lot easier than carpet and really i don't think it's that bad. mist out the worst of the mud and sand with a hose and then take a brush to it. works everytime
Herculiner YJBully YJ Wrangler Technical Forum 7 06-15-2007 01:52 PM
Covering Herculiner with Line-X (or another coat of Herculiner) frankiejr TJ Wrangler Technical Forum 3 05-01-2007 09:27 PM
Herculiner bmx_hb_guy YJ Wrangler Technical Forum 9 01-11-2007 03:27 PM
Herculiner on top of POR-15??? theboxman71 YJ Wrangler Technical Forum 12 12-13-2006 12:05 PM
Herculiner jeepteejay TJ Wrangler Technical Forum 10 09-29-2006 06:55 PM
