Herculiner? - JeepForum.com
post #1 of 8 Old 10-19-2001, 03:55 PM Thread Starter
Mikein
Herculiner?
Hey can someone tell me about Herculiner? What is it just a rubberizer to deaden noise or something better? What kind of prep do you need before applying? Any tips or replys appreciated.
88 YJ 4.2--Weber Carb
30" BFG A/T KO
Posi-Lock
Jacobs Mileage Master.
Mikein is offline
post #2 of 8 Old 10-19-2001, 09:40 PM
JeepTodd
I have the herculiner in my 87 Wrangler. It is a thin rubber type material, alot like rhino truck bed liner. It is really nice if you just want to hose out the inside of your jeep to wash it out. I noticed that the floor gets hotter because it is black and it is also noisier. I'm going to put carpet back in mine because I don't like the heat and noise. I don't ever get enough dirt inside to really make it worth while to just take the hose to it. Most carpets clean up rather easy by getting them wet and then using a vaccum. Depending on your use of your vehicle you might like it better than me.
1987 YJ, 4" lift, 33 x 12.5's, 4.2l
2001 TJ, 4" lift, 33 x 12.5's, 2.5l, air raid intake, air raid TBS
JeepTodd is offline
post #3 of 8 Old 10-20-2001, 03:26 PM
hog
I don't know about Herculiner, but I have my entire YJ Rhinolined, from the tailgate all the way up under the dash. I put it down as my best mod so far, it makes it so easy to clean (I haul a lot of sh*t around, and like to play in the mud).
I agree with JeepTodd stay away from black, (mine is grey), now there is a multitude of colors out there.
The only downside is it was not cheap to have installed.
Hog
hog is offline
post #4 of 8 Old 10-24-2001, 06:18 AM
bonehead99
bonehead99's Avatar
How much Herculiner will I need to do the inside of my YJ? Anyone one know of a cheap site to buy it, or another brand that is cheaper?
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #5 of 8 Old 10-24-2001, 10:20 AM
OhYeah
There is sale at Autozone, $99 for the kit and a gallon of Herc. I have been told this is more then enough to do a Jeep with couple of layers. I have heard Herc is some good stuff. Just buy it and read the instructions.
Peace,
91 YJ, 4 banger, 3" Rough Country, 3" body lift, 31X10.5 BFG KO's on 15X10 bajas, K&N, restrictor removed.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #6 of 8 Old 10-24-2001, 11:14 AM
RodeoRob
RodeoRob's Avatar
We did the inside of a YJ with one gallon from Kmart for $99. That was enough for two coats with a little bit left over.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #7 of 8 Old 10-24-2001, 07:22 PM
iJeep
I did the entire interior of my XJ with less than one gallon. It transfered the heat from my auto tranny a lot more than the carpet and it was much louder. It will keep the floor from rusting and a little easier to clean and harder to ruin.
iJeep is offline
post #8 of 8 Old 10-25-2001, 03:47 AM
bonehead99
bonehead99's Avatar
I went to Wal-mart last night and they sell a gallon of dupli-?(not sure the rest of the name) for $40. Anyone used it? What all comes in the herculiner kit?
Herculiner YJBully YJ Wrangler Technical Forum 7 06-15-2007 12:52 PM
Covering Herculiner with Line-X (or another coat of Herculiner) frankiejr TJ Wrangler Technical Forum 3 05-01-2007 08:27 PM
Herculiner bmx_hb_guy YJ Wrangler Technical Forum 9 01-11-2007 02:27 PM
Herculiner on top of POR-15??? theboxman71 YJ Wrangler Technical Forum 12 12-13-2006 11:05 AM
Herculiner jeepteejay TJ Wrangler Technical Forum 10 09-29-2006 05:55 PM
