helpp np231 problems - Page 2 - JeepForum.com
post #16 of 20 Old 01-20-2010, 09:45 PM
MJMPC
Check your motor mounts . Are you running rubber mMM with a poly trans mount ?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #17 of 20 Old 01-20-2010, 09:50 PM Thread Starter
bigred94
ill take pics after work tomorrow and im running browndog poly mounts ... the chain is deff slapping around in the and as for clocking how far do u drill new holes for the yj set up i realy dont like that whole idea of drilling could i just lift the trans up with a home made trans mount lift ?
bigred94 is offline
post #18 of 20 Old 01-20-2010, 09:58 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Redrilling isn't as traumatic as it sounds.
1) It's soft aluminum, so a simple hand drill will be fine.
2) The pattern just needs to be moved clockwise (looking at it from the rear) a bit. The 10 degree amount is not something critical, it just happens to be 10 degrees.
3) The t-case is "hub-centric" meaning that the case centers itself into the transmission, so if the holes need to be slightly enlarged to compensate for being a little off, it's no big deal.
4) The tranny/T-case mounting flange does not make a fluid seal, nothing will leak out.
Make a cardboard template of the pattern (using the existing bolt pattern) then rotate the cardboard template approximately the same as the one in the pic & drill it out.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #19 of 20 Old 01-20-2010, 11:10 PM
Douglas S.
I just finished up clocking an XJ ax-15 for my swap. This is what i recommend.
1. Take a file folder and use some spray adhesive (very little) to lightly glue it to the rear of the transmission (with hole cut out in center for shaft)
2. Take a hammer and lightly work your way around the outside, tapping the edge of the transmission. The extra material should break off cleanly.
3. Use a ball peen hammer to knock out the current mounting holes.
4. Carefully pull the template from the transmission
5. Figure out about where the template will go to rotate the t-case up approx. 10 degrees
6. Lightly apply spray adhesive and set the template in its new position (edges will line up so you can tell it is centered)
7. Drill new holes. I used a drill press, but you could probably get away with a hand drill if you are careful.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #20 of 20 Old 01-21-2010, 04:26 PM Thread Starter
bigred94
ok i got some pics there not the best off of my phone
sorry never posted pics before so this is the best way for now
i spun my front drive shaft has some slop in it and can hear the chain too
bigred94 is offline
NP231 problems? KB8UDE TJ Wrangler Technical Forum 9 09-25-2010 11:01 AM
NP231 seal problems zmw001pembroke YJ Wrangler Technical Forum 1 01-27-2009 10:46 AM
Helpp!!!! tommysly TJ Wrangler Technical Forum 1 04-04-2008 07:32 PM
NP231 Problems...maybe plasticmanhey TJ Wrangler Technical Forum 13 07-18-2007 10:53 PM
NP207 to NP231 speedo problems Austin_YJ YJ Wrangler Technical Forum 3 05-31-2007 07:16 PM
