helpp np231 problems - JeepForum.com
post #1 of 20 Old 01-20-2010, 06:38 PM Thread Starter
bigred94
i have the np 231 in a 94 yj 4.0 with the ax15 running 35s with 410s. when i take off i have realy bad vibs in the jeep, i was runing no rear dshaft and had the same vibs and its getting bad. wen i accerate hard right and 3500rpm it feels like the drive shaft is bidding but its not i cheaked it all out. only happens 1st and 2nd gear ive never blown up a tcase before so im unsure wat symptems they have before blowing. and the chain is realy loud realy loud on highway driving has fuild in it. anyone have any ideas??
bigred94 is offline
post #2 of 20 Old 01-20-2010, 06:46 PM
msprooch
Not trying to be a **** but using complete sentences and punctuations would help us help you.
msprooch is offline
post #3 of 20 Old 01-20-2010, 07:02 PM Thread Starter
bigred94
ok well sorry next time i will
bigred94 is offline
post #4 of 20 Old 01-20-2010, 07:07 PM
MJMPC
Remember the ft driveshaft is not balanced . Check your u-joints .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 20 Old 01-20-2010, 07:08 PM Thread Starter
bigred94
true but it shouldnt be the same vib as the rear
bigred94 is offline
post #6 of 20 Old 01-20-2010, 07:09 PM
kloppk
You ought to check the tranny mount. Over time they will start to tear and seperate allowing the tranny to shift around under high torque loads.
kloppk is offline
post #7 of 20 Old 01-20-2010, 07:12 PM Thread Starter
bigred94
brand new poly tranny mount but that woundnt give me bangin noises under the jeep under hard acceration
bigred94 is offline
post #8 of 20 Old 01-20-2010, 07:53 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Your profile says that you have a 2.5L, but it looks like you did a 4.0L swap. Is that right?
What model Jeep did the AX-15 come out of?
If it's an XJ AX-15, then your T-case might be hitting the skid. XJs have the T-case angled down 10 degrees on the drivers side & will interfere with the skid on a YJ.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #9 of 20 Old 01-20-2010, 08:07 PM Thread Starter
bigred94
yea did the 4.0 swap in november and had no problem until 3 weeks ago .. pulled out an zj in the woods and now i have the vibs and banging.. and as for the ax15 its yj but the jeep i took it out off it had a cut cross member in it. and i have a transercase drop in the jeep now maybe i should change out the tcase and cut the cross member .and hope for the best. the chain is crazy loud in it also
bigred94 is offline
post #10 of 20 Old 01-20-2010, 08:16 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
It sounds like a XJ AX-15 was put in the YJ you got it from.
When using a non YJ AX-15 in a YJ, the NP231 transfer case will hit the skid plate because the T-case is "clocked" 10 degrees lower on the driver side, but you can redrill the location of the mounting holes at the rear of the AX-15.
This pic & explanation were stolen by me from fellow JF member "idaholtby", he posted this in another thread a while back.
The transfer case clocking is determined by the mounting holes on the output of the transmission. Simply redrill the holes to raise the transfer case to the YJ height. In this pic, the holes on the right on each tab are the newly drilled holes that the YJ configuration requires to clear the skid plate.
Max
Mean Max is offline
post #11 of 20 Old 01-20-2010, 08:17 PM
93jeepyj
Maybe what your hearing is bearings that are shot in that t case, That will cause vibration on the highway Ive had it happen. Im also pretty sure the chain doesnt move in a 231 unless you're in 4wd so thats probably not the noise you're hearing. Has the t case even been run low or dry on fluid?
93jeepyj is offline
post #12 of 20 Old 01-20-2010, 08:22 PM
Jeeeeeeeeeeeeep
My jeep was making a terrible banging noise and it was the chain in the T-case. They get worn and stretched out and make all kinds of neat sounds... I've destroyed two NP 231's... When I find a good deal on one I buy it and try to keep a spare on hand.
1991 Jeep Wrangler 2.5L, 5 speed
2003 SVT Cobra Supercharged 32V 4.6L, 6 speed
Jeeeeeeeeeeeeep is offline
post #13 of 20 Old 01-20-2010, 08:26 PM Thread Starter
bigred94
yea probaly is an xj ax15 but the tcase is deff an yj and my front shaft aways moves if i put it in 4hi on the road i get no noise its not there anymore but the vibs are only there 1st and 2nd from dead stop and hard accleration is crazy it feels like the drive shaft is hitting the ujoints but its not theres no marks on it i have a spare tcase outa 4.2 auto yj im gonna switch see if it helps
bigred94 is offline
post #14 of 20 Old 01-20-2010, 08:41 PM
Jeeeeeeeeeeeeep
With the jeep in neutral grab drive shaft and spin it back and forth and listen for the chain to slap around in there... I could hear mine smacking the case when I did this.
post #15 of 20 Old 01-20-2010, 08:43 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
The origin of the T-case (XJ or YJ) makes no difference with respect to "clocking".
The difference is only in the AX-15's T-case mounting hole pattern.
If the T-case is touching anywhere (like on the skid) you will feel driveline vibs. While in lower gears (like 1st & 2nd) and under hard acceleration, the most torque is being applied to the driveline. Again, if there is contact (or really close tolerances) between the T-case & skid (or any other portion of the frame) you can expect knocking noises & vibes.
Pics of the T-case to skid clearance would be helpful.
Max
Mean Max is offline
NP231 problems? KB8UDE TJ Wrangler Technical Forum 9 09-25-2010 10:01 AM
NP231 seal problems zmw001pembroke YJ Wrangler Technical Forum 1 01-27-2009 09:46 AM
Helpp!!!! tommysly TJ Wrangler Technical Forum 1 04-04-2008 06:32 PM
NP231 Problems...maybe plasticmanhey TJ Wrangler Technical Forum 13 07-18-2007 09:53 PM
NP207 to NP231 speedo problems Austin_YJ YJ Wrangler Technical Forum 3 05-31-2007 06:16 PM
