Helper Springs or New packs - JeepForum.com
post #1 of 5 Old 08-10-2011, 07:48 PM Thread Starter
Rockabilly
I have a 93 YJ. I bought it with the current drive train and suspension. It has a High pinion currie nine in the back and a high pinion 44 up front. It has a SOA. The front sits 3 inches lower than the rear. I want to level it out. I am looking for info regarding installing helper springs out front to raise it. Has anyone else did something like this and will the helpers stiffen up the suspension and lead to less flex. I thought about just replacing the springs but I don't know how bad the current springs might be sagging so I don't know what to buy. The current springs are almost flat from one end to the other which leads me to believe they are probably worn out and really weak. I'd hate to buy a new set with a little lift in them and end up with the front higher than the rear. Any and all help will be greatly appreciated.
Rockabilly is offline
post #2 of 5 Old 08-10-2011, 07:52 PM
Duck Doctor
Add-A-Leafs will change your marginally rough riding rig into a poor riding rig. I installed helper springs on my CJ7 and YJ and both Jeeps rode terribly rough after the install. I'd suggest buying a new set of front springs.
Duck Doctor is offline
post #3 of 5 Old 08-10-2011, 07:59 PM
TheNewbie
I'd go new. Add a leafs won't hold up on SOA anyway.
If you can, I'd replace all 4 with the same springs.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #4 of 5 Old 08-10-2011, 08:53 PM
ZeroGravity
The springs may or may not need to be replaced but if you buy only front springs and it turns out to be not so level, you can always buy springs for the rear after the fact. Returning springs you don't need will cost you return shipping.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #5 of 5 Old 08-11-2011, 10:40 AM
hesserdude07
what springs are in it now?
Flat springs SOA work great, if you have a quality spring. They flex like crazy and offer a good ride...
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
bastard packs what springs did you use and what results ? kurtis1971 YJ Wrangler Technical Forum 10 07-06-2011 11:26 AM
Bastard Packs (Leaf Springs) jeepaholic91 YJ Wrangler Technical Forum 7 08-26-2010 11:08 AM
helper springs for snowplow Brew461 TJ Wrangler Technical Forum 25 11-25-2009 12:35 PM
Shift helper kit 2005 TJ?? JackMJeep TJ Wrangler Technical Forum 3 06-12-2006 06:06 PM
for loopy the best helper (need help again) Meister_jeep YJ Wrangler Technical Forum 4 08-09-2002 04:32 AM
