HELP!!! YJ rough idle - JeepForum.com
post #1 of 7 Old 02-20-2012, 09:35 PM Thread Starter
HD7908
I have an 89 YJ 4.2. I've replaced the carb with a weber, done a full tune up and time, and a nutter bypass along with replacing the intake and exhaust gasget's and even had a tech check my carb adjustments ant timing. the thing still runs rough at idle, really bad when its cold, and it gets worse when i out it in gear. Its an automatic trans by the way. It doesen't seam to be using oil so I'm running out of ideas here and I'm starting to wonder if the motor is shot.
Any ideas would be helpful
HD7908 is offline
post #2 of 7 Old 02-20-2012, 11:10 PM
04WJny
1987 YJ Wrangler
did the problem just suddenly happen or was it slow? did you do the tune-up and the other things after your engine problem? what makes you think its not using oil
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #3 of 7 Old 02-20-2012, 11:25 PM Thread Starter
HD7908
I bought it and It had the old carter carb on it and ran like crap all the time. I replaced that and it still ran like crap but better. Did the bypass and that helped with everything but the idle. couldent get the weber to tune in right so I took it to a tech and he found the intake gasget was bad so I replaced that. Now as long as its not at idle it runs fine, but at idle once its warmed up it evens out till you put it in gear. Fuel filter maybe?
HD7908 is offline
post #4 of 7 Old 02-20-2012, 11:26 PM Thread Starter
HD7908
I changed the oil two weeks ago and it doesn't seem to be losing any. It has a slight rear main leak, but there is no blue smoke.
HD7908 is offline
post #5 of 7 Old 02-20-2012, 11:42 PM
tyler1234567
I bet you just need to adjust the two brass knobs on either side of the carb right below the air filter plate. You can just turn them with a socket.
Also there is a flathead screw that is black. Its way down on the drivers side of the throttle body/carb and it has a spring on it. Adjust that either way until idle is stronger.
For the weber
tyler1234567 is offline
post #6 of 7 Old 02-21-2012, 12:02 AM Thread Starter
HD7908
What does that do?
HD7908 is offline
post #7 of 7 Old 02-21-2012, 01:41 AM
tyler1234567
Originally Posted by HD7908
What does that do?
if you play with those adjustments you can smooth out your idle.
2.5L Rough idle chadrenner69 TJ Wrangler Technical Forum 10 10-11-2011 04:40 PM
rough idle idle issue rescue913 YJ Wrangler Technical Forum 1 10-21-2010 06:57 PM
Idle Air Controller - Trying to Clean for Rough Idle - Need Help JBWood05TJ TJ Wrangler Technical Forum 21 08-24-2008 06:40 AM
help with rough idle TJRangler TJ Wrangler Technical Forum 4 02-19-2008 03:55 PM
Carter BBD fix for No Idle or Rough Idle ScotZ YJ Wrangler Technical Forum 0 03-26-2003 09:26 PM
