Help with Winch Sag in front - JeepForum.com
post #1 of 7 Old 01-30-2007, 02:11 PM Thread Starter
muddyfunkster
hi got a problem and need advice!
had my 2.5 inch lift on for 5 months and the winch on for a month. the front end of my 95 yj is now 2.5 inchs lower than the back. i have a 10,00lb winch and winch plate on.
I have the old springs still (which obviously arnt as curved as the newer lifted ones) but can i use these in anyway to add-a-leaf to my spring pack or something? or is a lift block or longer shackles the way to go?
when i finished the lift i actually got 4 " over what was on there and the back hasnt sagged at all! so it makes it look really odd with the front being lower!
Please help!
Cheers everyone from cold england!
muddyfunkster is offline
post #2 of 7 Old 01-30-2007, 02:36 PM
ramburger
can you post pics, that sounds funny-
get new springs....
ramburger is offline
post #3 of 7 Old 01-30-2007, 03:13 PM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
When mine sagged in the rear I did an add a leaf and it fixed it. But if your springs are old...and I see you have the worst springs available (procomp) just buy a new set. I can say that because I had pro comp too.
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #4 of 7 Old 01-30-2007, 06:01 PM
King03Kev
King03Kev's Avatar
1987 YJ Wrangler
Try adding a leaf or swap the front springs with the back and hopefully all will even out. I can't believe they sagged that much, that sucks.
kevyj87 '87 I6 5spd, 215,000+ miles, Herced, Nuttered, Weber, HEI, RE 4", 1" BL, 4:11's, np231, 33x12.5's, SYE & shaft, 1" brown dog mm, home made bumpers front & rear, Ramsey 8,000lb winch
King03Kev is offline
post #5 of 7 Old 01-31-2007, 10:02 AM Thread Starter
muddyfunkster
sorry wrote the original message with a migrane, ill try again!
i had the 2.5 inch procomp lift which gave me 4" of lift when first installed. (over what i had with sagged springs)
lifts been on for 5 months and the winch for 1.
the jeep now still has the bigger lift in the rear with no sagging at all, but the front has sagged to around half the height of the front.
wat can i do to lift the front end just a little? to even it out.
like i said ive still got the old springs, can i add a leaf somehow? or will a lift shackle do the job?
what have you guys done to correct the sag from your winchs?
thanks again for help!
post #6 of 7 Old 01-31-2007, 10:45 AM
RealJeep
I put a winch on mine and it didnt sag it that much at all. Winches arent that heavey where they would sag it half the difference.
1992 Wrangler Sahara, 4.0L HO, Dynomax exhaust, Kc daylighters, 4" pro comp suspension lift, 33x12.50 BFG MT's, 15x10 rockcrawlers, hurst shifter, Off-road bumpers, SYE, 2-10's, MM 8000 Winch, ARB Snorkel, MORE Boomerangs, CB
RealJeep is offline
post #7 of 7 Old 01-31-2007, 11:08 AM
crazymon01
crazymon01's Avatar
i had an old school 12k LB ramsey winch on the front of my jeep for a while til i down graded to an 8k LB winch and i have had this second one for bout a year now with little to no sag at all..... i thinkin u may be havein another problem....
4.0
I6
ARB snorkle
307 -> 411 gear swap
lock rite locker on the dana 35
33 x 12.50 Mickey Thompson radial MTZ
4.5" Rubicon Express heavy duty Suspension Lift
currie boomerang shackles
8,000 lbs. Winch
bikini top
tonneau cover
pictures??
crazymon01 is offline
Winch on the front of my JK? reznik572 JK Wrangler Technical Forum 5 08-24-2009 07:01 PM
Low COG front Winch Bumper & Winch? Sarge_ TJ Wrangler Technical Forum 15 09-24-2008 07:51 PM
winch or front locker? ionakana YJ Wrangler Technical Forum 30 06-19-2007 10:30 AM
Winch sag: how much did your front end drop when you put on the winch? STW TJ Wrangler Technical Forum 24 12-16-2006 10:55 AM
BB w/ Winch (Front End Sag???) nwquadriders TJ Wrangler Technical Forum 4 05-19-2005 02:17 AM
