Help! Welding near gas tank? - JeepForum.com
post #1 of 17 Old 05-09-2011, 06:59 PM Thread Starter
crazycow1028
Alright so im trying to patch up some rust holes on my frame towards the rear shackles. i've never welded before, so im having my friend do it with his(serious lack of money, i can barely afford a torque wrench ) but the plastic gas tank is worrying me. i dont really feel like blowing up anytime soon, should i drop it or will it not be an issue?
you know you own a jeep when your girl friend gets jealous of how much attention you give the new tires
crazycow1028 is offline
post #2 of 17 Old 05-09-2011, 07:04 PM
Mark05059
just drop it.. it will make it alot easier for him to weld and alot safer as well.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 17 Old 05-09-2011, 07:05 PM
Unlimitedlou
As long as you are not welding right on the gas tank and not melting the plastic, you should be fine. To take an extra precaution, take an old towel and wet it and lay on the gas tank where you are weling.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #4 of 17 Old 05-09-2011, 07:11 PM Thread Starter
crazycow1028
alright yeah thanks. since i have to weld on the inside of the frame rail and there like a 3" space between that and the tank im probably just gonna drop it. do i have to drain the gas tank first or disconnect any lines?
post #5 of 17 Old 05-09-2011, 07:22 PM
WakeDoctor
What is the purpose of wetting the towel? So you can have something you cool your burns after you have extinguished yourself?
WakeDoctor is offline
post #6 of 17 Old 05-09-2011, 07:22 PM
jcmooreusmc
You don't have to drain the tank, but it makes it much lighter and easier. Just remove the screws holding the filler hose in and start dropping slowly. I used a floor jack b/c mine had fuel in it. also had a buddy watching for lines to get too tight. I diconnected the fuel filler hose, the fuel pump power supply, and the 2 hoses on top(can't remember what they're called). Check this out......courtesy of Mean Max. http://www.jeepforum.com/forum/f12/h...emoval-981049/
jcmooreusmc is online now
post #7 of 17 Old 05-09-2011, 07:29 PM
soonermatt
Um the welder gets steel to 2600 degrees using electricity. Your wet towel would make some interesting fireworks before things got bad.
soonermatt is offline
post #8 of 17 Old 05-09-2011, 07:30 PM Thread Starter
crazycow1028
thanks man that helps a lot! im a bit new at a lot of this so it a lot of guesswork/trial and error alright now i just have to wait for the sun to come up
post #9 of 17 Old 05-09-2011, 07:32 PM Thread Starter
crazycow1028
I think the purpose was to further protect the gas tank, but thats not a bad idea either. especially with a few beers in you
post #10 of 17 Old 05-09-2011, 10:18 PM
raynmaker
no doubt the metal being welded gets to 2600 but the stray spark cools quickly and the wet towel will stop pin holes. Not that I recommend the method for gas tanks. For sure drop it. But i have used the wet towel to avoid scaring polished stainless.
Warning: This poster has infinite knowledge of useless information and redneck tendencies. Use info at your own discretion. :wave:
raynmaker is offline
post #11 of 17 Old 05-09-2011, 10:53 PM
bracs4
i just finished dooing this to minead def drop the tank its a tight spot even with out the tank in the way
bracs4 is offline
post #12 of 17 Old 05-09-2011, 11:36 PM
oldtime_ironman
Inside of the frame rail? I would say drop it even tho its a PITA it will make the welders job a *lot* easier and its safer not to burn thru anything even regardless if you leave the skid on. Making the welders job easier also tends to make it cheaper since its kinda tight up in there anyhow.
Yeah a wet towel works but frankly thats a "desperate" move for me. Like if I gotta do it on a Sunday and get to work Monday. Here's some other tricks for safety OK I have tried these:
You can take a bunch of gas from a MIG welder if that's what you have, and run a line full of it into the tank with the gas cap off. It shoves out the gas fumes. Hope you got your insurance paid up tho.
You can also dump out as much gas as possible, and then pour in a mix of hot water and liquid dish detergent. Shake it up real good. Do the welding and then drain/bleed everything like crazy for about a day.
Last edited by oldtime_ironman; 05-09-2011 at 11:43 PM. Reason: about wet towels etc
oldtime_ironman is offline
post #13 of 17 Old 05-10-2011, 07:59 AM Thread Starter
crazycow1028
thanks ill take that in mind. im not always the safest person so i wasnt sure if it was worth it but it seems to be a good idea. ill be welding today or tomorrow ill keep you updated on what happens
post #14 of 17 Old 05-10-2011, 07:20 PM
dodger889
If you leave the tank fill it to the top. A full tank has less gaseous fumes to light up. Second thing cover the gas fill point with a wet towel and use some sheet metal as a guard to keep the sparks off the tank. Now if you drop the tank do it outside then push the jeep inside to weld. Then cover the gas lines with a wet towel this will keep the fumes and gas from floating around your welding area.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #15 of 17 Old 05-12-2011, 08:11 AM Thread Starter
crazycow1028
i just finished it i didnt actually drop the tank i just used some wet plywood and a towel and shoved it in between. it turned out pretty well, i cant post pictures yet but its not bad. thanks for the help!
frame rot , gas tank , rust , welding
'87 YJ fuel tank pressurized after dropping tank? Gooch YJ Wrangler Technical Forum 9 11-10-2010 05:19 PM
Fitment issue with new gas tank and gas tank skid drum03 YJ Wrangler Technical Forum 3 10-02-2009 07:34 PM
gas tank skid bolts spin-cant drop tank dodgetk81 TJ Wrangler Technical Forum 0 04-08-2008 08:18 PM
Gas tank skid that requires no tank removal Thunderstrike TJ Wrangler Technical Forum 27 01-08-2006 11:41 PM
hrmm 15gal tank to a 20 gallon tank?? evilpsych YJ Wrangler Technical Forum 4 10-29-2001 06:15 PM
