help w/ carb. 258... Weber or Holley Pro-Jection? - JeepForum.com
post #1 of 3 Old 12-04-2001, 09:37 PM Thread Starter
Wrangler89
i also posted this in the "engines" forum, figured I'd get some more help. i have an '89 Wrangler YJ w/ a 258 I-6... it runs rough at idle and it runs rich, we've had 6 rebuilt carbs. on it already. we have decided to do one of two things: either get a Weber carb. or a Holley Pro-Jection kit. Will the Weber solve all of our problems or is it worth the extra $400 to get the fuel injection. i have heard some good things about the weber but I haven't heard much about the Holley FI... any help would be greatly appreciated
Wrangler89
Wrangler89 is offline
post #2 of 3 Old 12-05-2001, 06:04 AM
glm 87 wrangler
If you find a FI for 800 bucks let me know!
But if 400 bucks is all.GO FI! By all means go FI!After that get the TFI upgrade to set that jeep in real stong motion.www.driveajeep.com has info onthe TFI
I have a weber and run the TFI! Runs great! Just still a little cold natured.I paid 359.00 for my weber and 119.00 for the TFI.
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 3 Old 12-05-2001, 04:03 PM
dburton
I have the weber carb and have done the TFI upgrade and it still ran ruff.So I had helped a friend do what he called the nutter bypass on his CJ, which eliminates the computer now mine runs better after doing this simple little rewire job, but it makes it very difficult to pass emissions test if you have those which I don't here.
Darin
89 YJ 4.2L auto 3in lift w33 Goodyear MTR's Corpus Christi Tx.
dburton is offline
holley pro-jection? tintedfire YJ Wrangler Technical Forum 6 06-27-2006 08:27 PM
weber or holley? eche981 YJ Wrangler Technical Forum 2 03-30-2006 09:26 AM
Carb Help - MC2100 - Weber- Holley Jeep44 YJ Wrangler Technical Forum 8 10-14-2005 03:06 PM
Holley 600 4brl carb any good or should i go with the Weber 32/36? ookxtreme YJ Wrangler Technical Forum 2 09-28-2004 06:13 PM
Weber vs. Holley Toploader YJ Wrangler Technical Forum 0 04-01-2003 09:56 PM
