help!! turn signals dont work - JeepForum.com
post #1 of 14 Old 09-18-2002, 01:31 PM Thread Starter
tufmar
Hey guys, i hope you can help me on this, my turn signals dont work, they dont even flash on the little screen above the steering wheel, the other day they started to flicker really fast, and today, they dont even show up or work, but my 4 ways work?? i checked the fuse and it was ok, any suggestions?
93 YJ - 4.0 2" BDS 1" BL 33's
98 ZJ - 5.2 Limited 2" BB 31's
02 WJ - 4.7 Laredo 242 TC 3" IRO 245/75's
tufmar is offline
post #2 of 14 Old 09-18-2002, 01:35 PM
LoOpY
its probably your circuit breaker. if i remember right, theres a seperate circuit breaker that causes your hazards to flash. how to check it, i dunno, but if you look under your dash, right above the fuse box theres 2 silver cylinders. ones for your signals, one for your hazards. i think. or is one for your wipers? lemme go find a wiring diagram
LoOpY is offline
post #3 of 14 Old 09-18-2002, 01:40 PM
LoOpY
alright. figured it out. the 2 big cylinders are for your hazards and your flashers. theres a small square breaker in the box for your wipers. anywho. the rapid flashing pretty much tells you that thats where your problem lies. i guess if they get damp theyll break the circuit until they dry up, submerge your jeep lately? or maybe its just fried. <shrug> g'luck
LoOpY is offline
post #4 of 14 Old 09-18-2002, 01:46 PM
YJ_90
One of the flasher cans is for the turn signals (the left i think) and the other is for flashers. Replace one see if they work, if not replace the other. Hopefully that will work.
YJ_90 is offline
post #5 of 14 Old 09-18-2002, 02:04 PM
Jeepfreak81
Jeepfreak81's Avatar
check your bulbs first if you havn't done this... they usually flash faster when one burns out, or you could have faulty bulbs, mine was being stupid like this and i replaced the bulb even though it would light and it works again, also if you have submerged your jeep recently it could be cause... my turn signals filled witrh water burning out my bulbs soon afterward and then not letting anything work right... just a thought
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #6 of 14 Old 09-18-2002, 02:11 PM
LoOpY
but remember, he said his 4ways work. so the bulbs are fine
LoOpY is offline
post #7 of 14 Old 09-18-2002, 02:27 PM
Jeepfreak81
belive it or not mine would work too... the bulb that was out just wouldnt flash, the rest would. -- i just messed with mine last night pondering for a half an hour... its worth a shot... bulbs are cheap i dont know what a flasher costs
post #8 of 14 Old 09-18-2002, 02:29 PM
LoOpY
im assuming that when he says his 4ways work, that he means all of them. correct me if im wrong tufmar. anywho, im bored, will someone please come to the chat room??
LoOpY is offline
post #9 of 14 Old 09-18-2002, 02:36 PM
YJ_90
Flashers are about the same no more than $2 a piece.
Usually when they are burning out the lights will flash faster and then stop working.
YJ_90 is offline
post #10 of 14 Old 09-18-2002, 04:08 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I believe that the 4way flasher and the signal flasher are exactly the same .. swap them over and see what happens ..
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #11 of 14 Old 09-18-2002, 08:35 PM Thread Starter
tufmar
hey guys, thanks for all your replies, im gonna try your suggestios tomorrow, i have to much work tonight to fool around with the jeep, ill let you know how it goes, thanks, Joe
tufmar is offline
post #12 of 14 Old 09-19-2002, 07:45 AM Thread Starter
tufmar
I forgot to mention this, i didn't submerge the jeep, however, I did take off the bottom factory ac unit off the dash to get to my head unit to install speakers in the back, thanks
tufmar is offline
post #13 of 14 Old 09-19-2002, 01:02 PM Thread Starter
tufmar
hey guys, i replaced one of the cylinders (the relay) and it worked, thanks again for the advice, Joe
tufmar is offline
post #14 of 14 Old 09-19-2002, 03:39 PM
YJ_90
Glad we could help!
YJ_90 is offline
milage wont show up on screen and turn signals dont work need help fullwidthyj TJ Wrangler Technical Forum 5 07-12-2009 12:41 PM
turn signals and hazards dont work kale2s TJ Wrangler Technical Forum 7 12-23-2008 12:27 PM
Turn signals don't work BobA TJ Wrangler Technical Forum 5 08-22-2008 09:36 PM
Turn signals don't work m3meems TJ Wrangler Technical Forum 9 07-13-2008 03:37 PM
Headlights, Brake Lights, Turn signals dont work Optik45 TJ Wrangler Technical Forum 3 07-22-2006 02:07 AM
