Quantcast Help transfer case nuts missing - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Help transfer case nuts missing
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 05-01-2007, 01:38 AM   #1
kankan
Well I was going over the heep to make sure it is ready for its madden voyage and noticed that the nuts that attaché the transfer case to the skid plate are missing. Does anyone know what size and thread these nuts are so I can go pick some up at home depot.
Thank you Malcolm
YJ 4.0 HO, SOA with 3.5” BDS Springs, 3/8” Bonz shackles, 33 BFG A/T,
03 Dodge Ram 2500 Heavy Duty 5.7 Hemi, stock so far
Current Projects
Full width Danna 60s
ON THE Back Burner untill the axles are in
Comp Cut Rear
Stretching the rear with XJ Springs
kankan is offline   Reply With Quote
Old 05-01-2007, 01:43 AM   #2
Burnerman
UMM....There are no bolts that go from the tcase to the skidplate.. There are 2 bolts or nuts( depending on the mount) for the transmission. 3/8" I think. There is also a torque arm off the tranny mount thats a 5/16".
89' YJ Larado 4.0L,AX15
01' Grand Cherokee 4.0L
Check my Gallery for pics.
My Rebuild Thread
Take a minute and fill out your profile, Please
Burnerman is offline   Reply With Quote
Old 05-01-2007, 02:10 AM   #3
kankan
I now I am tired but I could of sworn that these studs were attached to the transfer case.
also should this bolt be tight or touching anything? Right now it is loose and nothing is touching it up top.
Current Projects
Comp Cut Rear
Old 05-01-2007, 02:17 AM   #4
bogger jeep
if you look close i think they go into a mount between the t case and back of tranny and the second one is the torke arm that bolt into a brcket on the top side. it should have rubber washers on the top and it shoud be tight, mine was loose for a long time but i finally got the thing tightened up.
bogger jeep is offline   Reply With Quote
Old 05-01-2007, 02:34 AM   #5
Burnerman
OK your's is differnet then mine. I use the 2 frt holes/ slots. Anyway 3/8" x 18 nuts should be it. I think..
My Rebuild Thread
Old 01-25-2008, 07:53 PM   #6
YJames90
aka Jamesx2
YJames90's Avatar
Mine looks the same, i was sure my new mount has threads on it that connect to the skid plate. I havent installed it yet
My 2.5 to 4.3 swap thread
http://www.jeepforum.com/forum/f12/4-3-swap-has-finally-begun-1237704/
If your going to talk about me talk to me
YJames90 is offline   Reply With Quote
Old 01-25-2008, 08:32 PM   #7
bigh20rnr
1987 YJ Wrangler
It looks like its your transmission mount and torque arm bolts. Replaced my transmission mount a couple weeks ago it had collapsed to the point the transfer case was hitting the skidplate. Had to use a jack to hold the transmission in place then lowered the skid plate to remove the mount then put it back together again. I have the old BA 10 and the mount was in a different spot but I think its the same thing. Not sure the size of the bolt and nut that was on the mount. If your mount is worn out anyway may be a good time to get a new one at autozone $24.99 I think and then take it to a local hardware store to get new nuts and large washers for it.
Rick
87 YJ 4.2L, Weber 32/36, rear bumper tire carrier, nutter bypass, RE 4 inch lift, SYE, AX 15, lined the body tub
"Baby when you said you wanted a project jeep I expected you to spend a lot of money on it" <---Worlds best wife!!!
bigh20rnr is offline   Reply With Quote
Old 01-25-2008, 09:42 PM   #8
goatboy
Ya know, guys, I gotta confess something... asking the size of fasteners on these forums is so...well, I was gonna call it something non-PC... Come on, if yer gonna work on these vehicles, ya GOTTA be able to puzzle this simple s**t out! Take fifty bucks go out and get an assortment of common fasteners 1/4" thru 1/2" so you always have some in stock, and TRY THEM OUT where they need to go!!! OR use the thread gauges that are available!
SHEESHHH!!!!
goatboy is offline   Reply With Quote
Glock Forum
